Thread: Vacation and SWG
    kne's Avatar
    Jun 2015
    Concord, CA
    133
    Vacation and SWG
    Is it ok to bring a pool up to SLAM levels while running a SWG? We just turned on the SWG for the first time this season last night, I have been solely adding bleach the last couple of weeks.
    I am heading out of town Thursday early and will be back late Sunday. I'll have the solar cover on and CYA is up to 40 (as of last test, there is more currently in the sock). I'm wondering/hoping that if I douse the pool right before I head out along with the SWG I wont drop too low. I know 4 days isn't a long time in the scheme of things, but when I found you guys last year was after a short trip, and returned to a green pool. Yes, in that case I accidentally left the filter and swg off, but it just happened so fast.
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    Jun 2011
    Long Beach, CA
    2,778
    Re: Vacation and SWG
    What size and brand of SWG do you have?
    With a cover on and already at SLAM levels, the SWG can add too much chlorine and it could possibly get sky high depending on the run time and output settings.
    kne's Avatar
    Jun 2015
    Concord, CA
    133
    30,403
    I wouldn't touch a thing. It sounds like you have your SWG tuned in just right so it should be the same when you return.
    kne's Avatar
    Jun 2015
    Concord, CA
    133
    No, I've been using bleach only. I have just turned my swg on for the first time this season last night. That is why I am a little worried. i have it set for 6 hours right now, I'll test tonight when I go to bed and when I wake up to see what the difference is. (I run it at night as electric rates are cheaper, I've seen that people say it's better for daylight, but I haven't researched the reasoning behind that yet.
