Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: New the TFP method..need advice
    Jun 2016
    Austin Texas
    22
    After reading as much as I could I decided to make the move to the TFP method and leave behind the vicious cycle of high CYA, algae, drain, spend money at leslies and repeat over and over. I have some mustard algae so I referred to the board and am addressing it with pool bleach.
    FC: 2
    cya: 75
    p: 7.5
    I have a in ground pool with pebble tec liner, intelliflow variable speed pump, cartridge filters, UV filter and solor heater.
    Based on the mustard algae shock chart (http://www.troublefreepool.com/threa...rine-CYA-Chart) and my CYA it said I need to get FC up to mid 40 level which would take 6 gallons of 10% bleach. Does that sound right or is that too much?
    Jul 2015
    Central Valley CA
    1,109
    Re: New the TFP method..need advice
    Welcome to the Forum! 6 gallons could be right depends on the size of your pool which brings me to your first homework assignment Can you please fill out your signature with details about your pool similar to what I have in mine this will help others guide you or at least double check your chemical add as you progress. You can find a link to your signature in the quick links dropdown just below the Rules button at the top of the page.
    If 6 gallons is the correct amount you may want to consider dumping some water if that is at all practical to make your SLAM easier. SLAM is a process not a onetime level adjustment and if you truly have mustard algae you could be at it for several days and that could get expensive. Depending on your situation you may not be able to dump water but we like to keep things as inexpensive as we can. Also what test kit do you have there are a few recommended kits but for a SLAM the best is going to be the TF-100 with an XL option added on from tftestkits.net Others will be along shortly with even more homework but for now pool size will get things started.
    Edit... of My Edit you were looking at the mustard chart so yes around mid 40 is correct
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2014
    15,274
    texag99, welcome! I would just clarify a couple things for you before you hit the bleach too hard. Most people actually find that they don't truly have MA as described in the Pool School - Mustard Algae page. I'm not discounting your opinion, just want to be cautious. Also remember that even for those who truly have MA, the initial treatment is still a regular SLAM FC level. You only increase to MA level for 24 hours AFTER passing the regular SLAM 3 criteria. I don't want you to waste bleach or expose the pool to more chlorine than needed. More is not always better. It's the consistency of the SLAM that's just as important.
    Also, while we wait to see your signature updated, it doesn't look like you have a SWG correct? So you know now that your CYA is a little high. So you have the option of lowering that now with a partial water exchange if you chose to do so. As you can tell from today's heat, summer is not too far away, so you may end-up with a summer CYA of 60-70 anyways, but for the SLAM I just wanted to point that out. Either way you chose will work.
    Nice to have you with us, and we hope your SLAM goes well. Once complete, remember to never let your FC go below that minimum FC number based on your CYA. Good luck!
    Jun 2016
    Austin Texas
    22
    OK...added sig. 13,500 gallons. I have the complete poolcare dpd test kit from leslies (free and total chlorine, ph, acid and base demand, total alkalinity, calcium hardness, cya). I am seeing some slight yellowing on the side walls mostly in the shaded area. Its very light and I can take my hand and brush it off. I recently did a half drain and then another 1/6ish drain but water is expensive here so I am trying to ration as much as possible.
    Thanks for the help
    13,500 gal in ground pool with pebble tec liner, intelliflow variable speed pump, cartridge filters, UV filter and solar heater.
    Jun 2016
    Austin Texas
    22
    I got the FC level up to ~30 for the slam however my PH level has skyrocketed as well. Is this normal when using liquid chlorine as I don't recall this happening with the power powder stuff that leslies sells?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    pH is invalid with FC over 10. Assume it's what it was before you started SLAMing.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Austin Texas
    22
    When is best time to add bleach during day? My pump runs from 9-6...I assume u want it running when u do the daily addition?
    Jul 2015
    Central Valley CA
    1,109
    you are correct you want the pump running other than that does not matter when you add under normal circumstances. While doing a SLAM Maintain is the most important step so you want to test frequently as practical and keep at the Shock Level until you have CC at or below .5 clear water and pass OCLT test.
    Jun 2016
    Austin Texas
    22
    Came home at lunch and checked with multiple tests and my FC is around 15. In order to find this I had to put 1/4 pool water in with 3/4 tap because my test only goes up to 10. The concerning thing I am seeing is that when I add the r003 to get TC is almost doubles. Does this mean there is still algae in the water and if so, what do I need to do now? The water looks great and the ph is around 7.8.
    Update: The test seems inconsistent. When I part it with half pool/half tap water it still shows 10ish on the fc but when I quarter it I see it drop to about 4ish. If its around 4 with 1/4 pool water I would multiply by 4 to get 16ppm. If that's true, then I should see that reflected when I use 1/2 pool/1/2 tap water correct? I think I made a mistake leaving my solar heater on when starting the SLAM yesterday as it take a long time to cycle thru.
    Feeling frustrated...thanks for the help
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    That assumes a proper test kit. You cannot SLAM your pool without one.
    Jun 2016
    Austin Texas
    22
    Ok so I must have the tf-100 from tftestkits.net? The taylor complete pool test kit will not work here?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    2005 or 2006?
    Jun 2016
    Austin Texas
    22
    Looks like its the 2005 since it only goes up to 10ppm. Is there an add on I can get or do I need to spend another $70 on a test kit. I just bought this one from leslies last week before I started reading this site.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    How does $26 sound? TFTestkits.net
    Jul 2013
    Columbus, Ohio
    114
    Quote Originally Posted by texag99 View Post
    You need the FAS/DPD test kit. That lets you accurately test high levels of chlorine. I already had the Taylor kit when I found TFP, so I just supplemented it with the FAS/DPD kit. I'll buy the complete TF-100 when I need to replace my Taylor kit down the road. The tftestkits site has the individual test kits also.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    Jun 2016
    Austin Texas
    22
    Good, I ordered the $26 one. I guess I will just leave the pool alone until I get the kit or is there anything else I should do?
    Jan 2014
    Buckeye AZ
    807
    you can use your current test to at least keep the FC right near 10.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2016
    Austin Texas
    22
    How long should it take for the FC to come down. My test should be here tomorrow but with the other one I can clearly tell that it is well over 10ppm and when I half it with tap it is 15-17ish. I am in Austin texas and figured with 2 days of full sun and temps in the upper 90s that it would drop quickly or is my high cya allowing it to hang around?
    Thanks
    Jun 2014
    15,274
    If you have no algae, then your high CYA will slow-down FC consumption. I lose about 2.5-3 ppm FC with a CYA of about 60-70. So you might figure about the same or slightly less (2 ppm) the way our days have been lately..... HOT! No worries, it will come down.
  20. Back To Top    #20
    Jun 2016
    Austin Texas
    22
    How much bleach are u adding per day with a 18k gallon pool and cya at 60-70?
