Thread: Attaching stairs to a composite deck...
    Jun 2016
    Virginia Beach, VA
    2
    Hi All! I'm new here. Great forum, BTW. I have a 15' round AG pool. I tore down the old shaky deck we used to enter the pool, and built a new, sturdier one. I used composite decking on the top. Is there a preferred method to attaching the stairs to this material? I have the Conifer Curve stairs. I'd have to screw into the composite if there's a cleaner alternative...
    Thanks!
    Wbrian (in Virginia Beach, VA)
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    333
    Re: Attaching stairs to a composite deck...
    That's the easiest way to do it. Be sure to pull them out regularly to clean and brush under them.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    I have the same situation (composite decking to which ladder will attach). I plan to align the ladder's hold down fasteners with spaces between planks and screw down to sacrificial scraps of lumber beneath decking to avoid putting extra holes in the composite planks.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Jun 2016
    Virginia Beach, VA
    2
    Thank you both. I am thinking about doing the same thing. I worry about screwing in and out repeatedly... I may drill a half in hole where the screw shouldn't be, and run a wood scrap across the bottom of the joists. Then use a long bolt...
    Thanks again!
    Wbrian
