Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 118
Thread: How to clear your pool, aka Taking one for the team!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    This is my personal backyard swamp! There is a huge oak just to the right of this pool that manages to drop every single leaf it possesses into the pool. I would like to say that I allowed my pool to go swampy as an altruistic sacrifice to demonstrate how easy it is to take your pool from swamp to sparkling using the TFPC method, but the truth is I got busy and lazy and allowed my pool to end up in this state. But as long as I have the opportunity I'll turn this into a teachable moment. I started yesterday by scooping out all the leaves.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    15,040
    Re: How to clear your pool, aka Taking one for the team!
    Alright!
    JoyfulNoise's Avatar
    May 2015
    13,187
    Following!!
    You really neeeeeed about 15lbs of dichlor, some copper & bromine based algacides and about 25 lbs of Alk-Up. Just dump it all in and swirl that around a bit. Give it a day or two and you should be good to go!
    If you run into anymore problems just post back and I'll give you lots more "helpful" advice
    Matt
    38,262
    Wait ... are you saying that the Mods allow their pools to become swamps?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Subscribing for the transformation.
    And JoyfullNoise - Without a sarcasm emoji, a helpless web surfer may actually see your advice and follow it. "#sarcasm" needed above.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2014
    Rogers, AR
    424
    I have often wondered if they ever do LOL I guess we now know the answer
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    38,262
    Mine has not gone swamp, but I certainly let the pH get away from me over the winter and the debris to pile up.
    Jul 2009
    Houston, Texas
    9,377
    image.jpgI will say in my defense that I tore the meniscus in my left knee last September and things kind of went downhill from there. But time to move forward! Yesterday after scooping leaves for an hour I added the first couple of doses of bleach (total of 6 jugs) efficacy was questionable since the bleach is left over from the fall and as swampy as my pool is I did not expect to hold chlorine anyway. Pump has been running 24/7 on low, and due to life and prior commitments I have not been home all day. I'm about to test, then go dump some more old bleach in before I have to go to another commitment and hopefully pick up fresh bleach on the way home. I'll add today's water picture from my phone when I get the chance. I must say, scooping swampy leaves is a smelly business!
    Love TFP? Become a
    TFP Supporter!
    May 2015
    13,187
    zea3,
    Don't forget, you're going to need to change your filter sand since it has gone "bad" and make sure you get some floc in that pool ASAP!! Oh, and you shouldn't use "dirty" bleach because it will raise your TDS. The bleach isn't working because you have "chlorine lock". Get some cal-hypo instead...a 25lb bucket should be all you need. Just dump it all in at once and let it sit at the bottom so you can create a "slug" of chlorine to defeat all of the "chlorine lock" you have.
    (Hehehehe ... playing "pool store" is fun....)
    Matt
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    zea3,
    Matt: You failed Pool Store 101, as you forgot to use scare tactics to make a sale of Phos-Free! They'd fire you on Day 1!
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    May 2015
    13,187
    Quote Originally Posted by JayBauman View Post
    That was going to be in my next post after zea3 has gone on for another day with the SLAM. You gotta rope them in real gentle like, you see? You give a few chems, the cheaper stuff, on Day 1. Then when they come back with a little more frustrated you hit them with the next shelf up on the chemicals. You keep that going and you up-sell them each time.
    Don't worry, I've got method to the madness. I'll drain his HER wallet in no time.
    Matt
    Jul 2009
    Houston, Texas
    9,377
    Sorry, I had to correct an error in your post!
    Love TFP? Become a
    TFP Supporter!
    Jul 2009
    Houston, Texas
    9,377
    Quote Originally Posted by zea3 View Post
    Despite the old bleach I do note some improvement from inky black to olive khaki. My test results are....drumroll please: FC 0, pH 7.5, TA 60, CYA < 20. CH was not tested. I'll have to go pick up some CYA tomorrow.
    Love TFP? Become a
    TFP Supporter!
    May 2015
    13,187
    My bad
    Wait, you have 0 FC and your CYA is low ?!?!?!? You know what that means ....
    A M M O N I A
    Quick, get 15 buckets of water and add varying amount of bleach to them so we can determine the exact amount of ammonia you have and get into complicated arguments about exactly how much FC is needed to perfectly eliminate the ammonia.
    Also, when you add more CYA tomorrow, which you should before neutralizing the ammonia as per pool store methodology, you should just toss it all into your skimmer. Oh, and just for good measure, make sure you add a couple of bags of dichlor too...
    Did anyone check your phosphate levels yet...
    Matt
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    On a more serious note....Zea, I see that you're in Houston. My pool hit 90° today. I should imagine that you've got your work cut out for you dealing with the kinetics of algae multiplication at these water temperatures. Maybe you should convert to Baquacil.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Following!!
    You forgot the floc, ha ha.
    Dang, see you had that covered later. Lol.
    May 2015
    13,187
    On a more serious note... Maybe you should convert to Baquacil.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    I did get a little over confident/lazy last summer and got some algae and had to SLAM last summer. But, the water stayed clear and we swam through the whole SLAM. First SLAM since 2012! It was scandalous!
    Jul 2009
    Houston, Texas
    9,377
    My bad
    A M M O N I A
    Ha! I have an ammonia test and it is clear. 0 Ammonia! Phosphate remover is the one thing I have not had the local pool store try to rope me into buying.
    Stopped by the HEB for a night's supply of bleach. There were only about 3 jugs of the plain stuff left! People must be swimming in the stuff!
    Love TFP? Become a
    TFP Supporter!
  20. Back To Top    #20
    May 2015
    13,187
    Well, all the cool kids in The Deep End are using phosphate removers...you wanna be cool, right? You want everyone to like you, don't ya? Huh, huh? Come on, everyone's doing it...you don't want to be the ONLY ONE not trying PhosFree...just a little won't hurt you....
    Matt
