Results 1 to 14 of 14
Thread: Pool Calculator App
    Jun 2016
    Mechanicsburg, PA
    66
    Pool Calculator App
    Just curious to know if the pool calculator app is still a good app to download or is using the website version better? Saw some bad reviews on the app not being updated and didn't know if there was any support for it anymore. Thanks
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Pool Calculator App
    Didn't know there was an app. I just use the website version which works as advertised.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jun 2016
    Mechanicsburg, PA
    66
    Quote Originally Posted by mikemass View Post
    Same here. Just thought the app may be easier to use on my I-phone then the web version.
    38,242
    There is no official app. Also, you should use PoolMath and not the outdated poolcalculator.com
    kne's Avatar
    Jun 2015
    Concord, CA
    133
    On android there is an app called Pool Pal that I downloaded. https://play.google.com/store/apps/d...plb.pool&hl=en
    I just downloaded it last week, haven't had a chance to do side by side comparisons.
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Thanks jblizzle - Didn't even know there was an outdated version. Glad I've been using the right one.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by kne View Post
    PoolPal is very close to the Pool Math page last time I checked it out. AFAIK they use the same calculation formulas and I use PoolPal all the time.
    Isolated Spa - 345 Gallons
    Aug 2013
    Chicopee, MA
    43
    Same here. Been using to do my baquacil to chlorine conversion. If you read any of the developer's remarks he has it tied in with TFP readings. If you tap on say FC it will give you what you should have as a reading. It has other readings as well ANSI and others but TFP recommendations are in there also. I swear by it but I'm still learning!
    POOL-24ft Above ground, Vinyl 16000 gal
    FILTER-Hayward EC-40 DE filter
    TEST KIT- Taylor -K2006
    Dolphin Robot Cleaner S50
    38,242
    Pool Pal was developed by a member of TFP.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    I use a pool math app on iPhone. The Pool Calculator by Jason T. Linhart. Works like a charm.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    38,242
    Quote Originally Posted by Razorhog View Post
    I am not sure that is updated with the latest changes in PoolMath.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Changes? I just looked on the app store and it is now listed as Pool-Calculator by pSiFlow Technology.
    38,242
    Yeah, Jason sold the website and app a long time ago and since then we have made some updates to the functionality to the TFP web version: PoolMath
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I use pool pal to store my results but I think is off a little bit, still use pool math for my additions...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
