Results 1 to 8 of 8
Thread: Super Simple PVC Towel Pole
    JoyfulNoise's Avatar
    May 2015
    13,262
    So I decided that draping our towels over the wrought iron (and rusty) safety fence is getting old and decided to build myself a towel rack out of PVC. I have three (3) 1-1/2" deck sleeves that are design to accept 1-1/2" umbrella poles, so I decided to use one of those. A nominal 1" PVC pipe has an outer diameter of ~1.3" so I figured the pole could be easily constructed from different sizes of PVC pipe along with fitting to make the arms. Here's the parts list -
    Two (2) 10' lengths of 3/4" SCH40 PVC pipe (for the main shaft)
    One (1) precut length of 1" SCH40 PVC, ~ 2' length (for anchoring in the deck sleeve)
    One precut length of 1/2" PVC pipe, ~2' length (so that 3/4" PVC fitting can be slid on to them)
    Various 3/4" PVC cross fittings and pipe reducers to put it all together with
    Total material cost - ~$26
    Tools needed -
    Miter saw and miter box to make straight cuts (substitute a ratcheting PVC cutting if available)
    Pipe end dressing tool (to clean up rough cut ends)
    Measuring tape and marker
    Eventually I will need some PVC glue and some spray paint but this post will just show the rough, dry-fitted end result.
    So here's some pictures of the cuts -
    The plastic miter box has followed me around for years. It's cheap but boy have I used it for everything (I don't have a radial saw or bench cutter).
    I decided to cut the first 10' section of 3/4" PVC into 16" lengths (total of 8) for the towel arms. Here's the first cut -
    Eight more to go.....
    So now, to make the arms rotate, I used four 3/4" cross fittings threaded over a 1/2" PVC pipe with the appropriate 1/2 to 3/4 adapters. Here -
    Next, I measured and cut the 1" PVC pipe to fit into the 1-1/2" deck sleeve -
    I finally press fit all the parts together and, viola!
    Total time spent cutting and assembling, ~ 1 hour.
    I have not glued anything together yet as I may make some changes. I think I might use some SCH80 1" PVC instead of the 3/4" SCH40 PVC for the main shaft; with wet towels on the arms, the pole is going to bend a bit. I also may shorten it a little OR spread out the cross arms. Once I get it to my liking, I'll glue and paint.
    Anyone have any thoughts on best practices for painting PVC? Does it need a good white primer coat first? I have some very expensive exterior Dunn-Edwards Paint that I used on my house which is designed to hold up to Arizona's high heat / UV environment. I was thinking of using that instead of just cheap spray paint.
    Matt
    Jun 2014
    15,292
    Re: Super Simple PVC Towel Pole
    I have found PVC to be the "duct tape" equivalent solution to many DIY projects at my house. Nice job Matt.
    38,539
    Krylon Fusion or the Dual Paint & Primer from ACE is what I would try.
    I use the later on metal for my off-road vehicles often, the Fusion is more for plastics so might be better.
    May 2015
    13,262
    Quote Originally Posted by Texas Splash View Post
    Yeah, it's amazing. I have a bunch of pool floats and noodles lying around and I have another PVC project in mind to make a holder for them that I can hang on my block wall. A little PVC and duct tape and you can do wonders....
    Thanks, Jason!! I will definitely grab some next time I'm in ACE.
    Matt
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Great idea Matt. I think I might try this in a nice sturdy umbrella base.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    13,262
    Quote Originally Posted by domct203 View Post
    Dom
    Thanks. Sadly, things have been so busy for me that I have yet to paint the pole. I need to modify it a bit (shorten the height about 6") and bulk up the 1" PVC section that plugs into the deck sleeves with a little 20mil pipe tape. The OD/ID mismatch between the sleeve and the pipe is enough to make it a bit too wobbly. Unfortunately there's no perfect fit solution in standard SCH40 PVC so it needs a little tweak/hack to make it work.
    Also, the 3/4" PVC main pipe feels a little flimsy to me so it might have been better just to use straight 1" PVC or maybe SCH80 PVC. Something with a slightly larger wall thickness.
    Matt
    DeanG's Avatar
    Jul 2013
    Friendswood (Houston) / TX
    27
    Here's my PVC "Clutter Killer"
    16K In-ground, Free-form 16'x30', 3.5'/6'/4', Gunite, Original Build ~1996, Renovation 2016 (Wet Edge Luna Quartz (Aruba) & Travertine Coping), Pentair Globrite LED light w/ Intellibright Controller, 1 Hayward Skimmer, Pentair SuperFlo VS Pump, Hayward Aquarite AQR15 Controller & T-15 SWG Cell, Hayward Sand Filter w/ Variflow XL Multiport Valve, Pentiar MasterTemp 400K BTU Heater, Kreepy Krauly Cleaner, TF-100 Test Kit (w/Speed Stir)
    May 2015
    13,262
    Quote Originally Posted by DeanG View Post
    Awesome-sauce!!
    Matt
