Thread: LO CODE on my Hayward Heater
    Aug 2015
    macomb twp
    30
    I have Hayward H150FDN Universal H-Series, Low NOx, 150,000 BTU, Natural Gas, Pool and Spa Heater and I am getting a LO code with is a flow problem. I have my intermatic timer set for 755am to turn on and give my equipment power, then at 8am the Hayward pump turn on. Can the heater be on without flow for 5 min? Will this cause a LO error code? Another thing is that I have my Hayward variable speedpump at 1900 rpms, is this flow to low?
    May 2011
    Orange, TX
    66
    Re: LO CODE on my Hayward Heater
    Was it working before at the pump speed of 1900 rpms? Shouldn't be a problem there I wouldn't think. What type of filter do you have? If the filter has a high DP, (cartridges that haven't been cleaned in a long time), it can reduce the flow to where the heater won't fire. I had a very similar issue on my Hayward. I changed the cartridge filters thinking that was the problem, but it turned out that the pressure switch was stuck. I took the plastic end off (end where the water piping enters the heater) about 6 screws and that exposes the pressure switch on the piping. Gave it a tap with the handle of a screwdriver and the code went away and started working like normal again. The heater will not come on without flow, it can be enabled, but will not fire until a flow is registered.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    Aug 2015
    macomb twp
    30
    Its speratic. I wake up in the morning and its ok. Working good. Then a few hours later its back to LO code. Im very confused
    12 X24 10000 gallon, Hayward AquaRite Tcell-9 SWG, vinyl pool, liner, Hayward MAX-FLO Hayward variable speed pump, Hayward H150FDN Universal H-Series, Low NOx, 150,000 BTU, Natural Gas, Pool heater, Sand filter
