Thread: Interested in Pool Heater - need advice...
    Post split off from this thread. Moderator
    I Currently live in Long Island, NY with a 16x32 ig pool. I am thinking of getting a heat pump, can anyone quote me their monthly electric bill for the heater from May to Sept. Anyone with a gas heater would like to hear from you too. Thanks for you help.
    Please state your KWH including taxs and delivery if you can if not on Long Island. The way if figure it out is easy by KWH consumed in a month divide by overall bill. I average with tax , delivery .22 kwh and 1.80 therm for gas.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Interested in Pool Heater - need advice...
    Hi and Welcome to TFP!
    Ft Lauderdale, Florida
    1,455
    That should be the other way around.
    Total bill divided by kw consumed = cost per kw.
    The northeastern US is one of our largest concentration of heat pump installations, especially around L.I.
    Heat Pump vs Gas will mostly depend on your pool usage. If you use your pool very little, a gas heater will heat it up quickly. If you use your pool frequently, a heat pump will maintain your water temperature very efficiently.
    http://aquacal.com/index.php/sizing is our cost audit that will allow you to enter your specific pool parameters and cost of gas/elec to compare the cost of operation.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
