Results 1 to 8 of 8
Thread: CYA is high
    May 2016
    Oklahoma
    7
    CYA is high
    Hello,
    Somehow my CYA is sky high. Does adding baking soda impact CYA levels? Also, my pH is high. Can I lower my pH by adding muriatic acid without further increasing CYA?
    38,484
    Re: CYA is high
    Please take a look at these to get this straightened out ...
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    Baking soda only raises TA a significant amount
    Muriatic acid lowers pH and TA
    Neither have anything to do with CYA.
    How are you chlorinating your pool?
    Please post a full set of test results and tell us the kit you are using.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    May 2016
    Oklahoma
    7
    Re: CYA is high
    Thanks for the info. I'm guessing that my CYA has jumped up due to initially using pucks and haphazardly adding stabilizer. My current readings are: TC=1, CYA=180, Alkalinity=180, pH=8.2
    Pool store told me to broadcast 8 cups of baking soda once per week to "prolong the life of my liner". Is there any truth to this or any benefit to regularly adding baking soda irrespective of alkalinity levels?
    Oklahoma City, 24' above ground pool, 14,600 gal, 1.5 hp pump, sand filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: CYA is high
    Yes, but to Jason's question, how are you testing?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    30,431
    Re: CYA is high
    Your pool store is full of it. Only when you decide to do your own testing will you be able to manage your pool. Stay out of the pool store.....honest.
    38,484
    Re: CYA is high
    NO! there is no reason to randomly throw baking soda into the pool to protect your liner. Only add what your test results indicate needs to be adjusted.
    May 2016
    Oklahoma
    7
    Re: CYA is high
    Quote Originally Posted by Mr Bruce View Post
    I'm using 6-way test strips from walmart. I know I need to purchase a proper testing kit. It's on the list...
    38,484
    Re: CYA is high
    Well, until you do so, there is really no way to offer balancing advice.
