Thread: Autopilot Soft Touch SWG - Min flow Rate
    Tpham2001's Avatar
    Jul 2012
    SW Florida
    45
    Hi all,
    I found this interesting and just happened to found the solution or I think I found the solution to the problem.
    Story time...
    After installation of Hayward Max-Flo VS pump, SWG isn't working properly and I started to get algae.
    Took a sample to Pinch A Penny and they told me I needed chlorine and I asked them if they know the minimum flow rate or pump rpm for the SWG to work. They just pick a number from the air.
    Came here to look for a specific number and found to be 15 GPM flow rate or 1k rpm for it to work. Turned out I have to bump the rpm to 2k for SWG to work.
    I also found the manual for Autopilot Soft Touch at their website and it also stated min of 15 GPM flow for it to work.
    I also cleaned the cell, strainer, checked cables, and sensor. Scraped my knuckles a few times too.
    I hope this helps some of you who are in the same situation as I am. I'll keep you guys posted...
    Tee
    Lets go swimming! Wait, is the water 88*F?
    10k gallons - Kidney Shape pool complete with 5-zone Caretaker 99 in-ground cleaner, Hayward Clear Plus Filter, CX900RE Filter, Hayward Pump, 2HP Marathon Motor, AutoPilot SWCG, Hayward Navigator Pro Cleaner.
    JoshU's Avatar
    New Orleans, LA
    543
    Correct 15 GPM is the minimum. Ideally would be around 20 GPM. This does not translate back to a certain RPM setting on every pool as the flow rate differs from pool to pool.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Tpham2001's Avatar
    Jul 2012
    SW Florida
    45
    Re: Autopilot Soft Touch SWG - Min flow Rate
    Thanks for the response, I'll check it again when I get off work.
