Thread: Help! Filled pool, put chemicals in, it's green!
    Hello
    I filled my 14' Intex pool with my well water over the last few days. Last night I put the reccommended amount of bleach in and stabilizer in. This morning I woke up to a green pool with the stabilizer all laying in the bottom of the pool.
    I vaccummed out the pile of stabilizer and tested the water to find zero FC in it. I have since shocked it with a double dose of bleach.
    Will this clear it up or do I need to drain? I really don't want to run my well again heavily for the next few days so I'm hoping the shock will clear it up.
    Thanks for any pointers
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: Help! Filled pool, put chemicals in, it's green!
    Is it green and clear or green and cloudy?
    Have you had metal problems from your well water before?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    It's green and clear. I have a water softener which I had on for most of the fill. One day I turned it off to put about 1/3 of the water in.
    Brownish green and filter was brown when I cleaned it. How do I fix? From what I read it's caused by iron. Thanks
    30,421
    The fix is painful. Filter out as much as you can using papertowels etc. You'll get some of it.
    Then put a sequestrant in your pool . Jack's magic is a good brand. Keep your pH down around 7.2 and hopefully, it will put the iron back into soluble form.
    This will not take the iron from your pool but continued use of the sequestrant will sort of "neutralize" so it doesn't reappear.
    If you pull from that well, you will get iron.
