Thread: Recirculating pool while replacing sand in sand filter
    Jun 2016
    Homoerville
    1
    I have a Triton TR 60 sand filter and I am replacing sand, I noticed one of the laterals is damaged and I had to order a new one. Can I run the multi port valve on recirculate without putting the sand filter back together?
    donna smith
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Recirculating pool while replacing sand in sand filter
    I believe that you could, even if the valve is not attached to the filter. I have not done it before, so be ready to switch the pump off quickly if I prove to be wrong!
    Isolated Spa - 345 Gallons
