Thread: Generic Bleach ok???
    Nov 2014
    Palm Desert, CA
    99
    I had a reverse osmosis on my pool water yesterday and was going to get the FC back up using generic household bleach until my SWG gets going, but the technician said that would add other contaminants that could stain my pool. Hype or true? I need to start adding this morning. He said use dichlor.
    Also, the bleach doesn't say a weight. Pool math is saying 6%. It is a generic I bought at Smart and Final called Simply Value bleach
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Generic Bleach ok???
    It is fine, technician is confused or misinformed. Bleach, as long as not spashless or a special variety, is the same thing as liquid chlorine or shock that they sell at the pool store. It is just a lower concentration. It only adds chlorine, water and a little salt.
    It the bottle doesn't specify assume 6% strength and dose accordingly.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    This link might help. Pool School - Recommended Pool Chemicals
    We just grabbed bleach at Walmart. The bottle is 1 Gallon and it says on the side the concentration.
    15'x24'x52" Saltwater 5000 Oval AGP, Hayward S180 Sand Filter / 1.5 HP Power Flo Pump, Hayward AquaTrol Chlorinator, TF-100 + Taylor K-1766
    JoyfulNoise's Avatar
    May 2015
    13,263
    Liquid chlorine in all forms (store bleach or pool store LC) adds both salt and lye (sodium hydroxide) to your pool. Also, cheaply manufactured bleach can have metal contamination in it which is the primary cause of high decay rates in cheap bleach. BUT, none of these are at any concentration that would affect your pool. You can very safely use bleach in your new pool water.
    So the tech is likely just retelling the same misunderstood information about liquid chlorine without trying to actually understand what the reality is.
    Matt
    Jul 2015
    Central Valley CA
    1,109
    You probably already know this but just in case... You are going to need to add some CYA otherwise you will be burning through FC like crazy.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Nov 2014
    Palm Desert, CA
    99
    Thank you everyone!
