Thread: Ontario's own Magic...
    Hi
    I am from Ontario Canada and just found this great site. I inherited a pool 10 years ago and have learned lots mostly by trial and error.
    I have a cement pool that needs painting and decided to do it myself due to the high cost. I have watched a youtube video of a pool painting and cleaning and I think I can manage.
    I have emptied the pool took about 2 days.
    I have gotten to the end and water seems to be backing up a few inches. I am wondering how I can deal with this it's 12 feet deep.
    Any suggestions would be great.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Ontario's own Magic...
    Hi there from Ontario.
    Welcome!
    When you say backing up a few inches, you mean it won't empty fully? What are you using to drain the water?
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Hey! Welcome fellow Ontarian!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Do you have a bottom drain? Many pool drains have a hydrostatic valve built in which will allow ground water to come up into the pool if the pressure outside becomes greater than the pressure in the pool. This is designed to be a safety to prevent the water table from floating the pool out of the ground. If so, you may not be able, nor really desire, to get all of the water out unless the water table drops a bit.
