Thread: Hayward 200FDN -Leaking from bottom
    Jun 2016
    Regina, SK
    13
    Hello, I have a Hayward 200FDN heater that is leaking water. I was purchased in August 2013, so still fairly new.
    Any thoughts on troubleshooting and fixing?
    Also, is there a way to bypass the heater and just have the pump running so no water goes through the heater to avoid more leakage?
    Thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: Hayward 200FDN -Leaking from bottom
    You would probably need to install a valve and an additional pipe to bypass the heater. As far as troubleshooting check for loose fittings and corrosion on the pipes and heat exchanger.
    Love TFP? Become a
    TFP Supporter!
    Jun 2016
    Regina, SK
    13
    Thanks, any fittings in particular or need to take top and sides off?
    Jun 2012
    western NY
    1,562
    The only good way to find the leak is to open it up. Sometimes, depending on the heater model, you can see parts thru the burner tray to maybe get an idea where it is coming from. Most likely though, you will have to at least remove the top panel to see down inside.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Guaranteed that the heat exchanger is leaking. This is one of the issues with this brand and reason why I will not install them nor recommend them.
    You are past the warranty plus Hayward will never admit to this issue.
    If you have to see the leak, you will have to take the unit fully apart to get to it. This is a closed system so you can't look under the burner tray either.
    It is possible to have someone repair the hole in the heat exchanger depending on the location. However, if you have one weak spot, there are more of them just waiting to spring a leak.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
