Thread: Do I need to add CYA?
    MugZona's Avatar
    Jun 2014
    60
    Hi all,
    Do I need to add CYA? It's currently reading at about 20, but for whatever reason FC is holding really well every day in the hot desert sun, and the pool is crystal clear and feels perfect. I'm hesitant to add CYA right now because I'd like to be able to use a few pucks for a vacation later this summer, and because things seem to be going so well.
    Results this evening:
    FC: 2.5
    CC: 0
    PH: 7.5
    TA: 50
    CH: 775
    CYA: 20
    Matt
    13,000 Gallon IG Double Roman End with Steps PebbleTec Seafoam Green Pentair Clean & Clear Plus Cartridge Filter 320 1 HP Sta-rite pump (MPR6E-147L) TF-100 test kit Kreepy Krauly Cacuum
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Do I need to add CYA?
    If your daytime FC loss is acceptable to you, then no, no need to add more. You may find that as summer progresses losses rise and you can revisit the CYA level at that time.
    This is the beauty of the TFP method. You understand what is going on and through testing you make decisions based on what your pool does and how it reacts.
    Support the site
