Thread: When does a spa become a pool? Where to start?
    FlyAU98's Avatar
    Jul 2014
    Ft. Lauderdale, Florida
    59
    So I've successfully (except for the return of the dreaded black algae) gone BBB for a year and half on my pool...my dad finally got his swim spa leak fixed (after 4 years) and is ready to get it up and running again.
    Surprisingly, he has kept what little water was in it pretty clean, so its about ready once the pumps/filter are up and running again (some pool repair guy in handling that).
    Its pretty big for a plastic, in-ground spa. He says its 2,000 gallons.
    Do I just treat it like a full-size swimming pool?
    Anything special with the plastic shell? (i.e. no need for calcium harness?)
    15.5K gal, concrete, 1HP AO Smith pump, Hayward C1200 cartridge filter, Zodiac T5 Duo auto cleaner, 8 panel solar heater controlled by Hayward Aqua Solar GL-235
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: When does a spa become a pool? Where to start?
    With modern swim spa's there is no longer a clear line
