Results 1 to 7 of 7
Thread: Pool pump-The cause of a low frequency hum in the basement
    Jun 2016
    Boston, MA
    138
    First time pool owner. Sorry for this strange question.
    This is a 5 year old house with a swimming pool in the backyard. We recently opened the pool, and set up pool pump running 10 hours a day. Pool pump is about 30 ft away from the house and sits on a concrete block. Pool is between the pump and the house.
    Strange enough, when I am in the basement while the pump is running, I can tell pool pump is on. It is particarly clear while in the middle of the basement. It is like a low frequency compressor noise. Not loud, but it is there. Turn off the pool pump, the noise is gone.
    I put my ear against the some exterior and interior walls, you can hear the humming noise clearly while the pump is on. Anyone can pinpoint how to rectify this?
    - Air leak?
    - Excessive vibration? (Pump itself is not loud. When I stand next to it. I can feel ground vibrate a little. Talk to the pool boy, who said it is perfectly normal.
    Thanks so much.
    Massachusetts
    Vinyl Salt Pool 2011; IC40 SWG; Raypark gas heater; Sta-Rite Dynapro pump; Sta-Rite System 3 Filter S7M120; Pool size: app 25000 Ga
    first time pool owner. First year too.
    May 2015
    Jonesboro, AR
    32
    Re: Pool pump-The cause of a low frequency hum in the basement
    I put a rubber welcome mat under my pump to help with that problem. Google pool pump vibration and you might find something better that would work.
    18x36 Rectangle, 8ft deep end, 26k gallons, vinyl liner, Intellichlor IC40 Chlorinator, 1.5 HP Superflo Pump, Hayward Tigershark QC Robotic Cleaner
    Jun 2016
    Boston, MA
    138
    Do you mean bolt the pump on top of rubber mat? Good idea. Just wonder why I can hear the noise 30-40 ft away from the pump in the basement underground
    Massachusetts
    May 2015
    Jonesboro, AR
    32
    It does sound strange that you can hear it when the pump is that far away from the house. Mine is right next to the house. I do not have a basement. Maybe since your underground, vibrations are more noticeable?? The rubber mat helped. I did not bolt mine down but probably would have if the rubber mat didn't help. Anything to keep the pump from vibrating on the concrete should fix it or at least help.
    Jun 2016
    Boston, MA
    138
    Thanks a lot.
    I wonder if anyone else has the similar experience as me about noise (vibration) travel for that far.
    Massachusetts
    Jun 2012
    western NY
    1,563
    Quote Originally Posted by shiyang100 View Post
    Thanks a lot.
    Yep, I do. We have a shortline railroad who's shop is about a mile from the house. When I am in the basement during the winter months I can (could) sense a vibration. For years I could never figure out what it was. It only happened during the winter months and not all the time, mostly at night. A couple of years ago I noted that it was not happening any more. At least not all the time. It would show up on occasion though. We finally figured it out. During the winter months, they had two or three engines that had to idle all night long to keep the radiators from freezing up. A couple of years ago, they built an engine house to be able to keep them inside overnight. Now they can shut them down and the vibration is gone. Mind you this vibration could not be felt or heard, it was more of a 6th sense type of feel.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2016
    Boston, MA
    138
    Quote Originally Posted by danpik View Post
    Thanks so much. This is an interesting example. Since the pump is put on top of concrete block, and I can feel the vibration standing in front of the running pump, I guess the vibration just travels in the soil to my basement. I cannot feel the vibration, but I can tell the pump is running while in the basement. The humming sound is audible.
    Massachusetts
