Thread: INTEX 14X42 ULTRA FRAME adding hayward skimmer
    Jun 2016
    Racine, WI
    3
    Hello all!
    I'm just completing setting up my Intex pool for my 4 year old and am going to add a Hayward skimmer.
    I have a few questions.
    Should I just plug the original 2 intakes from the pool and just have the skimmer as the only intake or is there an advantage to having all three?
    Also, when attaching the skimmer, can I keep the gasket intact and cut the hole prior to installing the skimmer? I've seen it both ways when looking online.
    I plan to hard plumb everything in. Is there a link for the most reliable 40 mm to 1 1/2 adapters, or is it possible to do the plumbing without them?
    Thanks.
    Intex Ultra frame 14x42, Intex 2800 GPH sand filter, Intex CG-28669 SWG, Hayward SP1091WM Skimmer
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: INTEX 14X42 ULTRA FRAME adding hayward skimmer
    Depending on the number of returns you may be best off using one of the suction fittings as a return line after you add the skimmer.
    Jun 2016
    Racine, WI
    3
    Thanks for the reply. I appreciate it
