Results 1 to 17 of 17
Thread: Grey ring on stairs
    Aug 2008
    Hebron, CT
    79
    Grey ring on stairs
    I have a SWG pool with a vinyl liner. The pool is very clear and clean except at my stairs. There is a stubborn charcoal grey ring on my white stairs that is about 2-3" wide all the way around. It almost looks like soot from a fireplace. Any idea how I can remove this "ring"? Thanks!
    22,500 gal Lagoon shaped inground pool, vinyl liner, Hayward 4800 DE Filter, Hayward 1.5 HP super pump, Aqua Heat Pump, Nexus Pure SWG, Dolphin Triton PS, Hebron, CT
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Grey ring on stairs
    More info please....
    What are the steps made of, and please post a full set of test results. A picture of the spot would be good too.
    Also, please update your signature to include all of your pool info, limited to 5 lines of text.
    Go to User Control Panel, then Profile, then Edit Signature.
    That way you won't have to repeat the info when asked, and we don't have to search for it.
    Thanks!
    Aug 2008
    Hebron, CT
    79
    Thanks...I will do all of that. Might take a day or so to get the photo, but I will. Thanks again!
    Aug 2008
    Hebron, CT
    79
    I am sorry for the delayed response! Here are my recent test results, although the stain has been there for at least a season. I am trying to save the photo to a small file size, but I can't seem to make it small enough to upload to the site?
    FC: 6.5
    PH: 7.3
    TA: 90
    CH: 250
    CYA: 40
    Temp: 78
    30,408
    Has your pool water been pretty clear all along? Were you able to maintain your FC pretty well last season? Did the spot appear gradually or suddenly? What does it feel like when you touch it?
    Guest
    Quote Originally Posted by Reibeling
    FC: 6.5
    PH: 7.3
    TA: 90
    CH: 250
    CYA: 40
    Temp: 78
    Hard to say what the staining is but your FC is too high, your CYA is too low and your pH is iffy for a SWG!
    water-balance-tips-for-a-swg-t3663.html
    Just as a test, hold a vitamin c tablet on the stain for about 30 seconds and report back on what happens.
    11,969
    You should upload your photos to Photobucket.com, and then copy the IMG code and paste it in your message here. Choose the "large" size when uploading. It's easy, fast and free.
    Aug 2008
    Hebron, CT
    79
    Thanks for all the help. I have tried the Vitamin C tablet before and nothing happens. The stain appeared somewhat gradually and is only at the water level (it is not all over the entire stairs). It has not gotten worse and again, has been there for some time. My pool is crystal clear. This is my 4th year with the pool (built new) and I have always used commercial test strips until now and have usually been in their “acceptable” ranges. I have always thought I had “perfect” water. Prior to buying the TFP test kit, I took my water to Leslies Pool Supply to be tested. FC was 4, PH was 7.2, TA was 70 (they wanted it higher and I raised it), CH was 210, CYA was 30 (and I added 2 gallons of their product to raise it at a cost of $70). I recently got TFP test kit and I was surprised at some of my levels unless I am making rookie mistakes. I was very surprised to find that after adding 2 gallons to raise CYA it only came up to 40 (using TFP kit). Unless I am waiting too long to say I can’t see the “black dot” at the bottom of the test tube. I waited until I could truly see no part of it. Maybe that is incorrect? I have attached two links that I hope will show the stain on the stairs well enough for an opinion. Thanks for everything.
    30,408
    I never realized the stain was above the waterline until you posted the pic. My guess is that coming from the black coping above it. Since it looks like chlorine gets rid of it (as noted by it being clean underneath the water), can you raise the water level a few inches up to the black coping and let the chlorine clean it?
    Guest
    I think Duraliegh hit it on the head. You can also try a Mr. Clean Magic eraser.
    Aug 2008
    Hebron, CT
    79
    Thanks! To raise it that high I would have to fill the pool over the skimmers almost to the top of the liner. Would the Mr. Clean Magic eraser be safe for the pool water? Comet may also work, but I did't think that would be good for the pool.
    Casey's Avatar
    SW PA
    10,427
    I don't know if this would help you in the way of using natural products but I love to scrub my tub with a baking soda paste. Rub on and scrub with a brush... WALAA! Clean! Maybe just put it on the brush, wet it down with a few drops of water, scrub steps and wipe off with a cloth so it doesn't mess too much with the TA.
    Just thinkin, all natural and part of the BBB.
    Guest
    Many people use them on their liners with no ill effect. It's actually a very fine abrasive.
    Mar 2007
    Coastalish 'down easter'
    4,160
    That's just oils and sweat on the stairs. Follow Casey's advice on using baking soda or pH + powder on a scrubbie sponge and it'll go away. The Magic eraser will also work 8)
    Welcome here!!
    Luv& Luk
    -Ted
    11,969
    I had almost that exact looking scum line and use the magic eraser, worked great.
    Aug 2008
    Hebron, CT
    79
    I finally got to the project of cleaning the ring on my stairs and I wanted to provide feedback- The Magic Eraser worked great. I couldn’t believe how easily the stain came off. It also worked great cleaning the liner at the water line too. Thanks for the great advice.
    11,969
    Excellent!
