Results 1 to 11 of 11
Thread: Safety Rope Install after Build
    Oct 2015
    ELKHART, IN
    37
    Question Safety Rope Install after Build
    Anyone have any experience installing anchors for a safety rope?
    The pool has been completed and my PB failed to include anchors on both sides of the pool to hook a safety rope w/ floats to.
    I'm wondering if any has screwed anchors directly into the aluminum coping?
    Or should I think about trying to anchor through the coping and install lead anchors into the concrete?
    Any guidance from someone who's already done it would be appreciated!
    I've searched for two days now and can't seem to find anyone who's actually done it.
    Dave
    16x32x8 Vinyl ~22,000 gallons
    + Pentair Intellitouch + Intelliflo VS + Tagelus Sand Filter
    + Hayward CL220 Chlorinator + Pentair MasterTemp 200 NG Heater
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Safety Rope Install after Build
    How about attaching hooks to some pretty flower filled planters on each side of the pool and then just hanging the rope across it? You could put a cinder block in the bottom to give it weight and just fill it with potting soil around it. Fast, cheap, movable... <shrug> could be a solution, huh?
    Oct 2015
    ELKHART, IN
    37
    Hmmm...I'm trying to envision how this would work out. I think it might work, but I'd be concerned with kids pulling on the rope and toppling the topsoil and cinder block into the pool. Thanks for the idea, I'll research a bit and see if anyone's done it already.
    Anybody else ever installed a safety rope across a pool that's already been built?
    Dave
    Ellington, CT
    262
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Oct 2015
    ELKHART, IN
    37
    Thanks, I've seen these, I'm just not crazy about depending on a couple of sheet metal screws to be sufficient to hold the weight of 3 kids swinging from the safety rope. I just know eventually some kid will decide it's fun to hang from the safety rope or try and stand up on it, kids will be kids.
    But thanks for the suggestion, I might just have to try these and use concrete and hits instead of the sheet metal screws into the coping
    May 2015
    Rochester, NY
    39
    I would use anchors similar to my safety cover anchors. They screw up to hold the cover I the fall and then screw down in the summer. You could do it the opposite way. There might be a better solution but this would be my amateur advice and I would definitely install into the concrete. The pressure on my cover is intense so you would never need to worry about kids hanging on the rope!
    C.N.
    IG vinyl liner 20x40 Pool, Hayward S-240 Sand Filter and Hayward pump in basement
    Indoor Jacuzzi spa 500 gallons, Spa Marvel
    Rochester, NY
    Oct 2015
    ELKHART, IN
    37
    Thanks Chrissy, I like that idea, I suppose I would need to rig something up that attaches to the anchor, as the safety cover brass anchors only stick up out of the concrete about 1 inch. I'm thinking maybe a brass ring that slips over the anchor would work. Appreciate the simple solution, sometimes less moving parts is a good thing
    Mar 2016
    Easley, SC
    381
    I have some like the link above. My 7 year old has been climbing all over the rope even though we tell her not too... I have seen no signs of the screws coming out. If they do, I will use concrete anchors to reattach them thru the coping to the concrete. I liked the idea of the cover anchors until I thought about the kids stepping on them when they are walking around the pool. Feet can be tender, especially when you are not expecting it.
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Yep, my granddaughter thinks the safety rope is there for her amusement but then again I find myself swinging from it too. She's still learning to swim and won't get in the pool without it.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Oct 2015
    ELKHART, IN
    37
    Talking Re: Safety Rope Install after Build
    Quote Originally Posted by joshua5438 View Post
    Thanks for the feedback! It's good to know someone has actually installed this setup.
    Any possibility I could a couple photos of your setup? Maybe a close up and an overall picture? It would be very helpful if you could and would be a huge help!
    Dave
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    I like these. I might get a couple, I think the two screws would hold a lot of force, but if you wanted something heavy duty, drill the hole through the coping and into the decking behind it and use some mason screws,, the kiddies wouldn't be able to pull them out then
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
