Results 1 to 14 of 14
Thread: TF 100 kit, need help.
    Aug 2015
    Jacksonville North Carolina
    5
    Hello, just want to say I am so glad I foundthis site. I am hoping to have better luck this year. Last year I had algae andhad to empty the pool and start over. I purchased the TF 100 kitbecause I had so much trouble last year. I filled the pool with citywater at the end of last year and had it covered all winter. It has beenraining for so long, that it has only been in the last 2 weeks that I have beenable to try to get the pool ready. Today 6.13.16 I tested thepool water.
    Here are my readings using the TF 100 kit
    FC = 3.5
    CC = 1.5
    TC = 5.0 PPM
    Calcium Hardiness test 175ppm
    Total Alkalinity 250ppm
    CYA test, the black dot never went away. I followed the instructions and Icould see the black dot when the container was filled to the top.
    Thanks so much for your help,
    Joan
    AG Intex Easy Set 18 x 48
    5,455 gallons, city water
    Krystal Clear Pump Model 635T (dual suction and one inlet) Cartridge
    Keep up year round, Jacksonville NC
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: TF 100 kit, need help.
    HI! Great job getting the great test kit! Did you have fun using it! I love mine!
    How does your water look?
    If you could see the dot all the way to the top your CYA is low. Have you added any CYA (stabilizer) to your water since refilling?
    That will get you started.
    Kim
    Aug 2015
    5
    Kim,
    No, I have not added a stabilizer. I have used 2 gallons of liquid chlorine 10%from Walmart in the last week. So now Ineed to know how to get the water right, without ruining it again. What type of stabilizer should I used? I read about putting it in a sock and hangingit on the return. Also should I SLAM toget my FC & CC readings up. Thewater is cloudy.
    Thanks
    Joan
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    They sell CYA at WalMart and Lowes. It's usually labeled "Stabilizer". The ingredients should be labeled as mostly cyanuric acid.
    Yes, if the water is cloudy you should SLAM.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Welcome aboard! Great decision to get the right test kit!
    And that's just what you'll learn!
    * I don't see a pH value in your original post. Before anything else, you'll absolutely want to go out right away and use the pH test in your TF-100, and let us know your pool's current pH. Many of the things we'll discuss can or will modify your pH in one direction or another, so we'll want to know what we have to adjust for, and by how much. It's an easy test, it's in the little square blue box in the TF100
    * Kim's right...the dot not going away means there is 0 (or very little) CYA in your pool. Stabilizer will bring CYA up. You can use the Pool Calculator (Link's in my sig) to determine how much you need. There's no specific "brand", so anything you can find in Wal Mart's pool section is probably fine. It's all the same stuff. If WalMart or something similar doesn't have it, the pool store will, but don't let them talk you into a bunch of other "easier/cheaper/better" stuff! Get stabilizer. Don't add a bunch until we know your pH, since it can lower pH and if it's already low, that could be problematic if we aren't prepared to adjust for it.
    * Yes, you'll PROBABLY need to SLAM...the CC of 1.5 is too high. (It should be 0, or at most .5) Do some reading in Pool School (link's in my sig) to find out more. Essentially, CC is chlorine that's "killing things", and if it's high, it means there's lots of things what need killin'. Once we learn the full numbers, get some CYA in there, we can make a good call on how much bleach we'll need to SLAM this sucker.
    You're on the right track! You have a good test kit, you're using it effectively, you're paying attention to what it's telling you, and it seems like you're starting to get your noggin wrapped around where you're trying to go. Let's keep it up!
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Aug 2015
    5
    Thanks to all of you. So I just used the daily kit (K-1000) that came with the TF-1000.
    pH 7.2
    did not register any chlorine or bromine readings...water
    I will get the stabilizer on the way home from work tomorrow. I do have 1 inch tablets by CLOROX called Active 99 contains 99%Trichloro-s-triazinetrione. Now I am going to do more reading on the site about SLAM.
    Joan
    Jul 2012
    Tallahassee, FL
    30,444
    Once you start SLAMing the pool it will go fast. You have to get some FC in the pool to keep it from going all the way green.
    Get that CYA in ASAP. It will help protect the FC from the sun. You will still lose quite a bit of FC while it works to clear your pool of what it growing in it.
    Kim
    Aug 2015
    5
    I started slamming yesterday and I can see the bottom of the pool, it still cloudy. I ordered the CYA and it should be here today. Thanks
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    During SLAMing, best to use the FAS/DPD chlorine drop test, for 2 reasons :
    * It's much more accurate at the high chlorine levels you'll be running during SLAM
    * It will show you the Combined Chlorine (CC) in the pool, which is one of the ciritical values you'll need to monitor to know when you can stop the SLAM.
    After that, yes...my 'everything's going fine" typical process is to add chlorine every day (after a while, you get a real good feel for how much it uses), check the chlorine with the K-1000 every other day, and then FAS/DPD drop test once a week. If *anything* about the pool (clarity, smell, feel, anything) changes at any time, I immediately start using the FAS/DPD test daily until whatever it is is resolved.
    -Gordon
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Note, Gordon is referring to the FAS/DPD chlorine drop test.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    I am indeed, and should have been more specific. Thanks for the correction! My apologies.
    -Gordon
    Aug 2015
    5
    Received the CYA today. After cleaning out most of the leaves and adding 2 gallons of chlorine, I put 1/2 cup of the CYA granules in a sock and hung it in front of the return. I am running the pump and will take a reading tomorrow. ( The cya is from poolmate and states it is 98% cyanuric acid hydrate. I bought a 7lb bag, lol)
    Joan
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Do not rely on your CYA reading tomorrow...it can take a week or so for CYA to fully register on a test.
    -Gordon
    Jul 2012
    Tallahassee, FL
    30,444
    You can squeeze the sock to help speed it up. Once all of the CYA is dissolved and the pump has been running for a few hours you should be able to test for it.
    Kim
