Thread: Volleyball net for above ground pool?
    JenMichelle's Avatar
    Apr 2014
    St. Louis
    65
    I am wanting to get a volleyball net for our 24ft above ground pool. I have looked at ones online and maybe its just me but they all look a little cheap. Any ideas on a good one? I could attach it to the railings I guess but would rather it just go to the ground on the outside of the pool.
    24' x 52" AG / Hayward Sand Filter
    Hayward Power-Flo 2 Speed Pump
    TF100 test kit / Pool Rover Hybrid Robot
    St. Louis, MO *GO CARDINALS*
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: Volleyball net for above ground pool?
    I bet you could fabricate something out of PVC that attached to the sides of the pool and held a net on. If it were me, I'd spray paint the PVC too.
    Aug 2014
    Baton Rouge
    7
    One came with our AGP. Put it up once and then never did it again. The ball flies out of the pool very quickly and somebody has to keep getting out to get it back in. Needless to say we were over it really quick.
    May 2012
    Montville NJ
    545
    I could not find one I liked that would span my 27' round. I ended up making one. I bought a cheaper badmitton set, and used that net. I have a deck arounf 1 quarter of the pool. Two eyebolts in the end railing of the deck support one end of the net. A concrete umbreller support sits oppsite the eye bolts on the ground outside the pool. I took some extra umbrella masts I had laying around and put three together (with a small umbrella on top - why not) and put two eye bolts at the appropriate heigh through the mast. The net has stainless steel spring clips attached to bungee cords on each end. I keep the net rolled around an old section of pool noodle when not in use.
    To set up the net, I put the umbrella mast in the stand. I clip one end of the net to the eyebolts in the deck railing, and then unroll it across to the umbrella post and clip the other end in. The bungee cords provide the approprite tension to keep the net taught.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Apr 2014
    St. Louis
    65
    Thanks guys. After much research I'm afraid I'm going to just try to make my own. Thanks for the ideas!
