Results 1 to 11 of 11
Thread: My Liner Moved During Partial Drain
    Apr 2016
    Waterloo/ Ontario Canada
    32
    I have been doing a partial drain and I just noticed that in my deep end the liner has moved significantly.
    I am not sure if this is normal and when I refill it will go back to normal. I have stopped draining the water and have just started to refill the water.
    I have attached a photo, is this going to be a problem? Should I stop filling and do something about this?
    Thanks!
    65,000 liter / 17,171 gallon pool with vinyl liner. STA-Rite Sand Filter Model T-200BP-1. STA-Rite 1hp Pump Model MPRA6E-147L. Laars Lite 2 Heater with Jandy Control Panel. Hayward Chlorinator Model CL220. Intermatic Timer.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Re: My Liner Moved During Partial Drain
    Fill it ack up immediately and see if it reseats.
    How much water had you removed for it to float like that?
    In normal water table, the rule of thumb is to go no lower than a foot in the shallow end. But in high water table, that can still cause It to float.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    30,431
    The picture is tough to see but I think there is water behind your liner. fill it back but you may have to wait for the ground water to recede
    Apr 2016
    32
    I left just under 2 feet in the shallow end to be on the safe side but I guess I should have left more. Filling now...
    Apr 2016
    32
    Yes, I'm pretty sure there is water behind the liner now. Does that mean that is a hole in the liner?
    If there is water behind the liner, is there a way to drain it?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    It usually means you have a high water table, heavy clay soil, etc.
    Sometimes the pressure from the added water is enough to push back, so fill it as full as you can regardless.
    In theory, you could attempt to remove a small Paet of te liner from the bead track and attempt to pump out/suction some of the water, but you could also just wait a bit for dryer weather to see if the groundwater recedes on its own, and call in a liner company if it doesn't.
    Helpful Links:
    Apr 2016
    32
    Sooooo, good news, I woke up this morning and the liner has reseated completely. Almost exactly how it was, just a few tiny wrinkles that I can most likely work out with a plunger.
    I thought I was going to have to spend the whole week on this one... Thanks everyone for the great advice!!!
    May 2016
    Troy IL
    476
    That's amazing.
    When I first looked at the house my wife and I eventually bought and now live in, the vinyl liner pool kind of turned me off. I liked the idea of a pool, but I always thought vinyl lined pools were not as nice. I decided an in ground pool was all that mattered, and we bought the house. I'm learning that despite it's downsides, it's got some up sides too. Often, the problems that arise are repairable yourself. I've decided I could probably install a new liner in mine, but I know there's no way I could ever replaster a gunite pool.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    30,431
    Well, congrats to you too for having good common sense. That situation could have easily gone South but you did all the right things. I'm happy for you.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Jason, I'm delighted it worked out for you.
    If you ever need to do a water change again (though I hope you avoid same by using TFP method of sanitation) you'd be a candidate for the "sheet method" of water change.
    That's where you lay a big tarp or taped visqueen across the surface, and drain and fill simultaneously to maintain the water pressure to hold the liner in place against the water table. But hey, lets hope you don't need to go there
    Helpful Links:
    Jun 2012
    Butler, PA
    336
    Quote Originally Posted by Swampwoman View Post
    or taped visqueen
    Not many call it visqueen anymore
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
