Thread: Pool Pump Motor
    Pool Pump Motor
    When opening the pool the motor would not start. I think it may be seized up. Can anyone give me some info on how to unseize?? Also, the pump and motor has to pull water from the skimmer up a hill and it has been difficult to prime. Would increasing the horse power from 1.5 to anything higher help??
    In ground pool 18'x36' deep 6'. Aqua-rite salt system. Titan Heatpump 115,000Btu
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Pool Pump Motor
    I wouldn't increase the motor HP just to help prime the pump. Consider adding a check valve to the suction side plumbing.
    As for the motor, with the power off take the back plate off (the one covering the wiring) and you'll see the exposed end of the shaft. Turn that a quarter or half turn by hand or with some pliers, then try to start it up again. If it doesn't start, you can CAREFULLY try turning the shaft of the motor with the power on (when it's humming). Just remember there's exposed wiring back there and when it gets started it starts moving very quickly.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool Pump Motor
    Please update your profile to include your pool information/equipment in your signature.
    Go to User Control Panel, then Profile, then Edit Signature.
    Welcome to TFP!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pool Pump Motor
    Welcome to TFP!!
    A couple other tricks to try are giving the motor canister a couple of smart raps with either the butt end of a hammer or a 2X4 while it's on and humming - don't hit it hard enough to dent it! - this may free up a slightly oxidized part. You can also with the pump off! remove the pump basket and try to turn the impeller with a screwdriver - if you can get the impeller to turn, the motor should start normally when you put the basket back in and get the lid back on 8)
    If you can get the motor running again using any of these methods, check underneath the pump/ motor interface for leaks, it's very possible you have a shaft seal leak ( replacing a shaft seal assembly is a 'cake walk' and Spishex, myself and others can 'cake walk' you through it )
    Good luck with this, please let us know if you can get the motor running again
    Luv& Luk
    -Ted
    Apr 2009
    Central Minnesota
    74
    Re: Pool Pump Motor
    I had this problem once. It turned out that the start winding contacts were stuck and made the starting capacitor fail. I had the local motor repair shop replace those components and everything was fine.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
    Re: Pool Pump Motor
    This happened to me last week. Take the back off and replace the capacitor. Its a $5 item and 5 minutes to replace.
