Thread: New pump, barely moving any water
    Jun 2016
    Wichita, KS
    5
    Our 3/4 Hayward power-flo kicked the can after about 10 years. You could literally hear the thing from a mile away it was so loud and was losing power daily. I picked up a 1 HP maxi-pump from a local pool store for about $270 (after tax). Model number AC 1000mxv. The new pump however is barely moving any water. I don't understand what could be wrong other than it is just a bad motor. It has higher HP and a higher GPM than our old pump, but is barely working at all. Is it just a horrible brand or what?
    10,000 gallon AG. Sand filter (both filter and pump hayward). Pump is a single speed. Pool is 10 years old, liner replaced last year. Test kit: K-2005.
    30,415
    Re: New pump, barely moving any water
    What is the psi on the gauge? Is the pump basket completely full of air or does it have a lot of air?
    Jun 2016
    Wichita, KS
    5
    PSI is 12. The pump basket is full of water with minimal air. I backwashed for a couple of minutes until the water ran clear, it apparently had been a long time since that had been done, because that seemed to alleviate the issue. It is flowing nicely now, I guess without the loud incessant hum that could possibly be classified as psychological torture it just didn't seem right.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Hayward is a good brand. We recommend backwashing the filter when the pressure rises 20-25% above clean pressure.
    More here, Pool School - Maintenance and Cleaning of Pool Filters
