Thread: need a little advice
    Every year I open my pool I have leaks. The worst place is always the two conections from my multiport to my sand filter. I back them off, then tighten them a little bit at a time. Still a slow or fast drip. Should I replace those things that screw on? Do they wear out? I think I need a new sand filter. It has a small crack around where all the bolts are. And it has always leaked there. Also I have never been able to use my skimmer. there is a small leak somewhere. I always have a little air in the system. Do multiports wear out? I probably need to hire a pro. Not sure who to use here in southern maine. Thanks.
    18k IG 16'x32' vinyl liner Haywood S-200 high rate sand filter pump Haywood Encl.3 1hp A.O.Smith Corp
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: need a little advice
    could you upload a picture of what your talking about, maybe someone will be able to help
