Thread: How Long Should It Take a Stabilizer to Dissolve?
    May 2016
    Atlanta, GA
    89
    I am working on getting my CYA up from 20 to 40. I have following the advice of the boards and put it in an old sock and submerged it in my skimmer. It's been 24 hours. Three questions. 1. How long should it take until the sock is empty? I was shocked to find it is still full after 24 hours. 2. How long do I need to run the pump for 24/7? 3. I know it takes a while for the CYA to register. In the meantime should I be calculating/adding chlorine based on a CYA of 20 or my goal CYA of 40?
    TIA!
    Kristina
    14.5'x32' irregular shape Pebble Tec SWG pool; 12,000 gal; Purex Triton Tagelus Sand Filter; Pentair IntelliPh Ph Controller
    triptyx's Avatar
    Apr 2016
    1,438
    Re: How Long Should It Take a Stabilizer to Dissolve?
    While the sock is in the skimmer and the pump is running, use your hands to crush and moosh the sock - you'll find you can dissolve a couple of pounds in no time.
    Running the pump is only necessary until all the CYA is dissolved from the sock.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    I'm impatient about that so when I need cya I put the sock in a bucket of scalding hot water.
    I let that sit for an hour then squeeze / squish the sock until it's all dissolved in the bucket
    then slowly dump that in front of the deep end jet.
    It takes about 10-15 min of doing that to get it all dissolved.
    Dolphin E10 Cleaning Robot.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It depends some brands of CYA dissolve easier than others
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    I found the one from Wal-Mart, Clorox Brand goes fast, still you need to squeeze every once in a while... ��
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Jun 2013
    Otsego, Michigan
    8
    I used the HTH in a sock infront of the return and 4 pounds was gone in less than an hour with a little massaging.
