Thread: Pentair SD-40 Lateral Pipe won't separate from valve
    Jun 2016
    Belleville, IL
    2
    Hi! I am having trouble separating the lateral pipe from the valve assembly. Any tricks? I'm assuming sand/crud/etc. is lodged between the pipe and valve making this difficult. I've tried heat (hair dryer), a little WD-40 (with a towel underneath to prevent it from entering the filter), and some rubber mallet assistance. This thing won't budge!
    Thanks!
    Jun 2014
    14,970
    Re: Pentair SD-40 Lateral Pipe won't separate from valve
    Hello and welcome to TFP! Sorry for the delay on your first post here. We were hoping someone with personal experience about your SD-40 model filter might chime-in and respond. So it's time to give this post a little for some more visibility. Hopefully someone will reply if you haven't already fixed the issue. Nice to have you with us!
    Jun 2016
    Belleville, IL
    2
    Quote Originally Posted by Texas Splash View Post
    Thanks for the warm welcome and bump! I think the question should apply to a lot of sand filter owners, as the design is very similar across the board...laterals attached to a center pipe that slide into the valve assembly on top of the filter.
    I was able to break the pipe loose and twist it a little with a rubber strap wrench this evening, but it still won't slide out of the valve assembly.
    30,402
    All the things I would suggest you have already done. I wish I could offer a trick but maybe others can chime in.
