Results 1 to 10 of 10
Thread: Iron stains
    Apr 2016
    Portland/OR
    66
    Iron stains
    Hi there: I've read a lot about how to remove iron stains (confirmed with a vitamin C tablet test). With my CYA around 30, I keep FC at 3-4 and pH around 7.8. It seems to me I'm seeing more orange spots on the bottom of the pool. Is the high pH making this worse?
    The pool store said I had .1 iron and .1 copper in my water - is this reliable? The numbers don't seem that high given other posts I've seen. Trying to decide if I should embark on this mission: www DOT troublefreepool DOT com/sticky.php?s=2298
    I just got done tackling an algae issue in our newly acquired pool which was unused for 3 years. I'm afraid to let FC fall - should I use an algaecide if I do take FC down? It seems there are mixed opinions.
    Tina (TKO) ~ My Pool: In-ground concrete/white plaster kidney shaped (21x40x9(deep end)); ~28,000 gal; Pentair Superflo hp pump; Hayward S244T 300lb sand filter; TF-100 w/ Speed Stir
    Jan 2014
    Harrisburg, NC
    25
    Re: Iron stains
    Hi there. I'm not a TFP expert, but will offer my 2 cents based on recent experience. DO NOT let your FC fall to zero, or if you do, DO NOT SLAM afterwards, even though the SLAM post says you're supposed to do that. I learned the hard way
    You can see what happened in my thread: Help! Iron stains returned immediately
    2005 build, 16K gal, IG - vinyl, 3/4 hp WhisperFlo pump, sand filter, Polaris cleaning robot
    May 2015
    Mount Cheaha Alabama
    250
    Re: Iron stains
    Hey TKO.
    There's a definite relationship with the SLAM process and metals being deposited on pool surfaces.
    The higher your pH is the less likely metals will stay in solution - the more acidic(lower pH) the more free ions to bond to iron and copper molecules
    Bleach is Caustic so Slamming will raise pH and subsequently under the right dissolved metal conditions cause staining on liners & gunite.
    I'd advise against the whole pool AA treatment - far too many side effects.
    If your stains lift easily with a bunch of vitamin C pills in a sock just take your time and clean while you swim, but keep your pH down in the 7.2-7.4 range.
    after using a bunch of pills you will see FC drop, and possibly CC - don't get alarmed if your water started clear but has a light turbidity. The FC is being consumed by the free AA. Just monitor for a few hours and bring FC up gradually.
    Pool store metal tests are unreliable at best and complete garbage for the most part.
    They don't account for sequestrants in the water which are binding up copper & iron - which will drop out of suspension when pH goes high
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Re: Iron stains
    TKO, as an alternate to the AA treatment, I've had past success with the Metal Magic sponge test and dosing to the level indicated by the test.
    If you have metals, you need to sequester them anyway. I found that in my pool, the MM removed "fresh" iron stains virtually as well as AA without the shenanigans. Its not as "sure fire" as an AA treatment, but here's a link if you want to give it a try. http://www.proteampoolcare.com/image...SpongeTest.pdf
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2016
    Portland/OR
    66
    Re: Iron stains
    Thanks all for the responses - so I think I'll use muriatic acid to lower the pH to 7.2-7.3, then try the Metal Magic or some other stain remover. Besides Metal Magic, are there any other recommended ones?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Iron stains
    Jack's Magic Stuff is good too. But, I think MM is cheaper.
    Apr 2016
    Portland/OR
    66
    Re: Iron stains
    Great - thanks. I'll get some ordered...so, muriatic acid to lower pH to 7.2-7.3 is recommended, right?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,765
    Re: Iron stains
    Right, it helps keep the metal in solution. High ph causes the metal to fall out of solution.
    I've used different (recommended) sequestrants and in your case I'd recommend specifically the Metal Magic. Its seems to work best at byproduct stain removal, it requires less top up to maintain, you can get good guidance off that sponge test link I gave you (for free, no expensive sequest test needed) and its cheaper, eg. Check out Pool Chemicals, Hot Tub Chemicals and Supplies | Pool Geek
    For Metal Magic, however, you actually need your ph a little over 7.5 for it to work optimally...it will bring the ph down a bit. So if you're going to use it, you don't need to lower ph as much.
    Helpful Links:
    Apr 2016
    Portland/OR
    66
    Re: Iron stains
    Great to know - thank you! I'll do some digging to see how much MM I will need for our 28k gallon pool.
    Update: I read your test link again, and all the info is there. It says leave pH 7.5 or higher, so maybe I won't touch it for now til after MM?
    May 2015
    Moorpark, CA
    171
    Re: Iron stains
    Quote Originally Posted by basod View Post
    I was thinking of doing a whole pool AA treatment myself. What are the side effects? I have light iron staining over the entire pool surface, except in areas I put an AA tablet.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
