Thread: Brand new Hayward Aqua Rite T15 showing no flow
    Jun 2016
    Sidney, OH
    1
    We just bought an Hayward Aqua Rite T15 salt chlorinator. We made sure we followed every instruction in the book before installing. We dumped the salt in the pool Saturday night and turned everything on. Sunday morning the no flow light was on. We do not have a flow issues, have checked the flow switch for continuity ( it was good), emptied baskets, and checked all the wires. Everything checks out. I have read through different forums and watched you tube videos. What am I missing. Our pool is in the direct sun and we are afraid to lose the balance if we mess with this much longer. We have a lot of money tied up in this and we were hoping this would make managing our pool a little easier. So far we are frustrated and I have a headache. Any suggestions?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Brand new Hayward Aqua Rite T15 showing no flow
    Welcome to the forum!
    So the flow switch wires shows 0 ohms with water flowing?
    You can try a jumper across the board terminals just to make sure it isn't a flaky connection.
    Good news is it is still under warranty.
    Mark
    Are you sure the flow switch is turned to the right direction when installed? It has an arrow on the top of it that shows which way the water should flow through it to make the no flow light go out.
    18x37 IG 22,500 gallons...Vinyl Liner...Hayward EC-65 DE Filter...Hayward 1HP Super Pump...Aquarite SWG...TF-100 test kit.
    Jun 2013
    Huntsville AL
    107
    Having the same issue. Did you ever get yours fixed?
    IG Vinyl, 20'x40' Sports Pool, Savannah Liner no border, 20' liner steps, 2 Venturi Renegade Skimmers, Hayward 1.5hp 2 speed pump, Aqua Rite 40k Salt system, Typhoon slide, Hayward Sand Filter, 22,519 gallons, TF-100 test kit
