Thread: Solar covers
    Apr 2015
    New Bedford, MA
    65
    Solar covers
    I just bought one for our 14x42 pool. My pump automatically turns on everyday while at work. How do I go about this if the cover is on? Do I remove the cover to add chemicals? If I choose to use a puck dispenser can I still keep it in the water?
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Solar covers
    It is fine for the pump to turn on and run with the cover on. You can flip the cover back to add chems. A floating puck dispenser? I don't think that would work.
    Apr 2015
    New Bedford, MA
    65
    Re: Solar covers
    I'm having a hard time keeping the chlorine in the pool with bleach so I've been also using the floating dispenser
