Results 1 to 17 of 17
Thread: Cloudy milky water with a SWG
    Jun 2016
    Heath Springs
    7
    I was told by a friend that works in a pool store that my water is cloudy/milky because I'm getting air in my filter/pump. After carefully checking all valves, o-rings, and tightening everything, there is no air getting in. All chemicals are balanced. I've shocked and used a clarifier. Still milky, so much so, I can't see my finger tips when I stick my hand straight down in the water. BUT... I noticed that the water around my titanium electrode (I have a SWG) looks milky. When my SWG is off and the pump is filtering with out making chlorine it is clear. My questions is, do i need to buy a new titanium electrode or is there something else I can do? Please help, I'm in the dog house with my kids!
    Intex above ground 18' X 48" round with Combination pump SWG/sand filter
    Jan 2012
    'burbs of Augusta, Georgia
    7,244
    Re: Cloudy milky water with a SWG
    We need a full set of test results to determine if its a chemistry problem or a filtering problem.
    FC
    CC
    pH
    TA
    CH
    CYA
    Jun 2011
    Long Beach, CA
    2,778
    Welcome to TFP!
    Have you inspected inside the cell for scaling, it will have a white buildup on the plates if there is scaling?
    Post the actual water test results.
    Jun 2016
    Heath Springs
    7
    FC 1.23
    CC 1.65
    pH 7.8
    TA 85
    CH 250
    CYA 45
    Yes I took it out and scrubbed it clean. Still milky
    Jan 2012
    7,244
    You test results make it appear very much like algae or other contaminate in the pool. Your FC is terribly low for a CYA of 50: FC/CYA Chart At no time should your FC be less than 4, with 6 being the goal FC level.
    Your CCs show its a chemistry problem (at least).
    Have you added calcium lately? Your vinyl pool doesn't need calcium so it doesn't need to be added. Calcium can sometimes make water milky for a short period.
    Have you added anything else to the water such as algaecide?
    Where is Heath Springs?? It helps us know what state you are in because water and climates vary in different areas.
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    The cloudiness you see while the SWG is creating chlorine is actually chlorine gas and is perfectly normal. I'm assuming that your cell housing is clear and you can see in it. My cell is clear and as long as the SWG is generating chlorine, I see the white chlorine gas rolling off the plates.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Jan 2012
    7,244
    Quote Originally Posted by carlos31820 View Post
    Sent from my SM-G900V using Tapatalk
    Carlos, that's correct for inside the SWG, but the OP has a pool full of cloudy water.
    Nov 2010
    Midland, Georgia
    353
    I just wanted to make sure the OP wouldn't try to make a connection between the SWG cloudiness as the cause of his/her problem since the OP asked about buying a new cell.
    Jun 2016
    Heath Springs
    7
    I've been working on it since beginning of May. Yes I added algaecide but over a week ago. I did add calcium but over 2 weeks ago. I live in SC. The pool store computer reading say the FC/CC is okay between 1to4 but I don't trust it because I think they try to sell you stuff you don't need. When I turn the SWC off and just run the pump the water starts to clear up, thats why i thought it was the titanium electrode. I'd love not to have to buy another one though
    Carlos,
    That's exactly what I thought! Thank you so much for confirming! I've just had problems with this combo filter and have had to replace parts so I just wanted to make sure since this has been going on for about 3 weeks now.
    Jan 2012
    7,244
    Do you know what kind of algaecide you put in? The brand?
    We don't routinely recommend algaecide use, and as mentioned before you never need to add calcium to a vinyl pool unless you have a heater to protect.
    Please review these short guides: ABCs of Pool Water Chemistry FC/CYA Chart
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,224
    It's highly unlikely the cloudiness in your pool is from the SWG. The cloudiness in the cell when it's running is the normal production of gas as Carlos mentioned.
    You'll be facing a decision very soon. Do I use TFP recommendations or continue listening to the pool $tore? Trouble Free Pool Care (TFPC) as taught here will clear your pool, and it will be safe and sparkly. Your pool is not safe at 1.5 PPM free chlorine and 45 ppm CYA, and when it's cloudy. The pool $tore is wrong, wrong, wrong. Their objectives are different from a pool owner's objectives.
    If you decide to go with TFP, order an approved test kit right away. If you then also follow TFPC, you will save back the $70 cost of the test kit before the end of July vs. continuing to listen them. There's easily over a 1,000 threads on this forum that will back this up.
    These two numbers - FC 1.2 and CC 1.6 tell the experts here that you're on the path toward a green pool and bacteria growth, if not already there. The experts here will guide you toward a safe, clean, sparkly pool.
    And welcome to TFP! Good to have you here and I hope you enjoy it
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Heath Springs
    7
    Not sure the brand. It was from the pool store. I'm at the point off draining the whole pool and starting over. We just want to swim!
    I absolutely will trust you guys over the pool store. Just wanted you to know what their computer readings were saying.
    needsajet's Avatar
    Jan 2016
    4,224
    That's great to hear. If your test kit is not already on the way, order this one as soon as possible TFTestkits.net
    Include the XL option (extra reagents to get you through a clean-up or an extra season, $15). People here love the speedstir ($35) if you don't mind the extra cost. It's optional.
    (I have no business interest in TF Test Kits. The Taylor K2006C is also an approved test kit)
    Glad you're headed in this direction
    Jun 2016
    Heath Springs
    7
    So is there a quick solution or is this going to take a while to fix? Either way, yall are the experts and I'll do whatever you suggest to get the water safe to swim in. Thanks in advanced!!!
    Jan 2012
    7,244
    Whether you drain or not, you NEED your own test kit to keep your pool healthy.
    If it were my pool I would drain and start again, after getting the tester so that I could put in ONLY that which it needs and nothing else
    And keep testing to monitor it.
    needsajet's Avatar
    Jan 2016
    4,224
    Drain and refill is my vote too. You'll be up and running as quick as that job can be done. You can skip the XL option on the test kit in that case, plus some likely headaches as well.
    And less spending on chems to eliminate the cloudiness.
    Jun 2016
    Heath Springs
    7
    Thanks guys!!! "Drain it" it is! I'll order the test kit tonight! I'll be in touch! Happy swimming!
