Thread: Can anyone tell which SWG cell is older?
    The previous owners of my house replaced the SWG cell but later determined that it wasn't the problem so they kept both. After taking it inside for the winter, they then couldn't remember which one was old/new etc. I can't tell either but I've helpfully labelled them 1 and 2, only because 2 looked a bit newer, but really a guess?
    Cell #1. On Superchlorinate, 25 V, 6.16 A, FC is 5.5 pre pump and 7.5 post pump at 50 GPM
    Also, this one reads a salt level of 3300 (pool store says 3100)
    Cell #2. On superChlorinate, 3.5A, FC is 5.5 pre pump and 6.5 post pump at 50 GPM
    This one reads a salt level of 3100, about what the pool store said.
    Can anyone tell me which one is newer? How much chlorine should it be making? It seems odd that #1 is running >6 A, when #2 has a label on it that says 5 A MAX.
    Both look nice and clean on the inside. There was a lot of buildup last year but a mild acid wash cleaned them right up.
    Thanks, Tim
    Oval pool, Aqua Rite SWG
    80000 l, 22000 Gal
    Vinyl liner, Sand filter, natural gas heater
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Can anyone tell which SWG cell is older?
    For what it's worth, I just replaced my T-Cell-15 and my label matches the one that is labeled #2 on yours. Not sure that is conclusive. I bet if you called Hayward and read them all the numbers on the label they may be able to determine manufacture date(s).
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    5E05: 5 year warranty, E means cell, 05 means made 2005
    3E10: 3 year warranty, E means cell, 10 means made in 2010.
    Support the site
