Results 1 to 8 of 8
Thread: pool clear, here are my test results-what next?
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Hi everyone,
    My pool is finally clear & cc<.5 & fc is holding overnight
    FC-12.5
    CC-0.5
    TA-110
    CH-80
    CYA-50
    pH-7.2
    I know the pH reading may not be correct with my chlorine level but it will drop by 1 tonight & probably 2+ tomorrow with the sunny day, so I will retest pH tomorrow night
    What else should I do? Pool calculator says get CH up to around 260, anything else?
    thanks
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    Butterfly's Avatar
    South Carolina
    10,045
    Re: pool clear, here are my test results-what next?
    Finally clear and FC is holding!
    Keep an eye on your pH. When FC drops below 10, I'd aim for 7.5 pH.
    You're done SLAMing when:
    Casey's Avatar
    SW PA
    10,428
    I'd actually bump the pH up a bit with borax. That's what I'd do.
    Jan 2009
    Cupertino, CA
    1,966
    With a fiberglass pool, CH is not so critical either.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by PaulR
    --paulr
    Actually it is, you do want the CH to be at least 220.
    "Critical" is a subjective word. With plaster having low calcium can cause significant damage to the pool. With fiberglass low calcium will slightly shorten the lifetime of the gelcoat and increase the chances of metal stains. I would say that calcium is critical with plaster and important with fiberglass.
    Jan 2009
    Cupertino, CA
    1,966
    Maybe I was mixing up vinyl and fiberglass? I thought there was some situation where low CH didn't matter.
    --paulr
    Vinyl doesn't care about low CH levels. All pools care about high CH levels.
