Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 93
Thread: A Deep Pool Build in Peoria, AZ -- finished, working on chem balance!
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Pictures and models of the design:
    Details about the pool:
    IG shotcrete 34x16x21 Grecian L shape
    22k~ gallons
    3'6 - 8'6 deep
    12x5 Baja ledge w/ 2 Bubblers
    14 feet of raised beam sheer descent waterfall in stacked travertine
    Custom stone diving board
    Hayward sand filter
    VS pump
    Aquarite T-15 SWCG
    A&A In floor system w/ Gamma 4 venturi heads
    Blue surf Pebble sheen
    Travertine paver decking (depending on hard dig)
    Cost with local pool builder: ~36k
    Instead of a traditional diving board, we opted to create a custom stone one, like the one below.
    Pros: Safer because of no spring, never needs replacing, lasts forever, looks pretty cool, takes up much less room (we have a small yard)
    Con: No spring/bounce, less fun?
    Picture of stone diving board:
    Drawn on ground layout:
    Start of dig:
    Day of first dig:
    Wow, so I signed back at the end of March 2016 and today June 13 they just started digging. Lots of delays with permits and a mess up with the first layout, plus it's the busiest season for pool building. For months I've been fretting about a possible 'hard dig' and the extra thousands of dollars that would have cost because we're digging an 8'6 deep pool. Well thank god, they started digging today and the test dig went down to over 9 feet 4 inches in less than 15 mins NO HARD DIG!! Even the diggers were amazed, as my neighbor across the street had a hard dig and many of the houses in this area (near mountains) end up paying much more because of the rocky layers here. I'm counting my blessings! I'm so very happy because that means I can upgrade my decking to travertine pavers now. Yay!
    I'll update as the build progresses
    For anyone curious: My neighbor paid 6k extra for her hard dig, and that was for a rather shallow 5-6ft play pool! So yeah, I was really, really not wanting a hard dig for my 8'6ft pool.
    Swim ready :) My Pool Build Thread. IG shotcrete 34x16 Grecian shape. 22k gallons. 3'6 - 8'6 deep. 12x5 Baja ledge w/ 2 Bubblers, 14' raised beam sheer descent waterfall in stacked rock. Custom stone diving board. Hayward sand filter, VS pump, Aquarite T-15 SWCG. A&A In floor system w/ Gamma 4 venturi heads, Blue surf Pebble sheen, Colorlogic LED. Future Travertine Sandcastle Owner.
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Re: A Deep Pool Build in Peoria, AZ -- it finally started!
    Already a small crowd lining up to watch It's actually pretty cool to sit and watch these machines work. I'm amazed myself.
    Jun 2014
    13,477
    Congrats on the ground-breaking! Now .... patience.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Congratulations! Looks like a great design!
    I did notice your images show your water feature wall 2 different shapes. One has higher pedestals on the ends and a low wall in the middle, the other has a high point in the middle with low ends. Just make sure they build it whichever way you are expecting.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,435
    Smurfy! Can't wait to see the progress. I was looking at your drawing and thought the gallons seemed a bit high. But I see a lower number in your signature which seems more likely. Did you consider a matching bench on the far side in the deep end? I can't recommend that enough. In our similarly designed pool they both get a lot of use, including the standing height benches. You can see pics in my build thread in my signature. Really like the diving board. Ins. co told us more accidents happen because people fall while on the board than from hitting bottom. Make sure the surface is very non-slip while wet. In fact, a non-slip surface was the IC's requirement. Won't apply to you since it's not a diving board but the safety concept is the same.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Quote Originally Posted by Nursenini View Post
    Good catch! Yes the water feature design went through a few changes before we decided on what to do. I'm still not sure which one we should go with, but it'll be one of those, lol Which do you like better?
    Quote Originally Posted by bmoreswim View Post
    I'm not sure which gallon is closer, I've seen different numbers, one from the engineers and one from the pool software. I think you're right though, and it's probably closer to the lower 22k gal. I'm not sure if making a parallel bench would intrude into the diving envelope. But pretty sure my PB would charge an arm and a leg at this point to change or add anything in the pool itself, so we'll most likely leave it as is. I've seen your build before, it's awesome! And yes, we'll have to find a way to add some sort of treading to the top of the board to make it slip resistant.
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Forgot to post colors for the pool:
    6x6 inch Royal Sea Blue Tile
    Smurf blue pebble sheen!
    Stacked travertine face
    Will also be choosing a light colored travertine paver for decking soon too
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Pics of the finished dig, 9.5 ft deep!
    Update: Plumbing and steel finished! They finished both within 2 days, and pre-shocrete inspection came by today too. I think we passed.
    Now for electric to be done on Monday, and shotcrete soon after
    Jan 2016
    Mesa, Az
    539
    Looks great!! It's going to look even better really soon. They shot mine yesterday morning and it's amazing how much more "real" it all seems when gunite is done.
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Thanks! I'm so looking forward to having a finished pool in time to finish out this summer heat!
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    As an additional side project we decided to remove our freakishly huge 8ft x 8ft sliding door leading out to our back yard and replace it with some custom 8ft x 8ft triple french doors. And let me tell you, these things were not easy to find in this size. The Home Depot rep laughed at me on the phone because apparently the only doors they regularly sell in that size are garage doors unless I paid almost 3k to put in a custom order through them. Luckily I found a small family owned door maker in Phoenix and got these beauties made for much much cheaper +1 Local Businesses!
    The problem with the original sliding doors was that it was not adhering to the local pool code for a household with children under the age of 7. We would have had to install some odd machine onto the sliding door to make them self-closing AND self latching slide doors. It was all very annoying to deal with, especially because our slide doors were larger and heavier than normal and would need a stronger system. Needless to say, I was not interested in some self closing contraption on my doors that had no safety to prevent it from force sliding on my 3 year olds little fingers. Also I heard they're prone to breaking. So we tore out the slider for french doors, with self-closing hinges and a reversed deadbolt/latch that follows pool safety code.
    Some pics for those interested:
    The original 8x8 sliding doors, I forgot to take a closer picture before
    Mid-install:
    Done:
    Just needs some paint to match the rest of the house's trim I'm pretty pleased with the result!
    Jun 2016
    Peoria, AZ
    154
    ^Very nice. Those are beautiful doors. I like the door handle up high where the kids can't open it. Just make sure your kids can get out another way in case of an emergency.
    Shasta pools just told me that I need a door alarm (I'm also putting in a removable fence) for the door. They didn't say I needed the door to be self closing. I'll have to look into that since I'm in Peoria also.
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, Pentair Intelliflo VS Pump, Pentair TR100 C Commercial Sand Filter, Stenner Econ T (NaCIO), Zodiac Baracuda Cleaner (coming soon), 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    I believe the choices are door and window alarms or self closing and self latching doors with handles 54 inches or higher.
    Here's the application with the rules: http://www.peoriaaz.gov/uploadedFile...pplication.pdf
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Just got a call, they're doing shotcrete tomorrow morning! Oh boy, looks like I'm going to be busy this weekend doing watering duty Can't wait!
    Aug 2014
    Houston tx
    2,498
    Great news!! Don't forget to post pics!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2016
    Peoria, AZ
    154
    Good stuff. Can't wait to see the shell sprayed.
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Shotcrete guys started setting up at just shy of 5:30am My neighbors are probably not too happy. The guys were super fast too, finished the entire job in 5 hours or less. So fast that I didn't even have time to take in-progress pics. Here's the finished shell though
    Jan 2016
    Mesa, Az
    539
    That'll be a good one!! The waiting doesn't get any easier from this point on though . . .
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Quick question guys:
    For Travertine Paver decking, what's a better base for AZ climate: Sand base or Concrete? I know sand has Pros in that it's easy to repair things underneath? But Concrete would stop weed growth?
    It seems my PB is still planning on pouring a concrete base down, but I'm wondering if I should stop them and just do a sand base instead for the pavers?
    Thoughts?
  20. Back To Top    #20
    Jan 2016
    Mesa, Az
    539
    Concrete would form a great base, but wouldn't drain unless you cored or left a sleeve in at the low points. Concrete would be harder to deal with if you ever had to expose anything underneath for repair.
    Sand would allow movement and drainage, but may need periodic maintenance due to differential settlement. I've got both situations. They'll be setting the tiles in sand overtop of my existing P-T patio slab, and the rest on just DG and sand. I'm going to ask that they lay rolled roofing felt down as a weed block before the DG gets placed and compacted. Also, polymeric sand, if used in the joints, is not conducive to weed or moss growth.
