Page 1 of 4 1234 LastLast
Results 1 to 20 of 78
Thread: JUST got TF-100 HELP please
    May 2016
    Lynchburg, VA
    66
    OK, so I just received my TF-100 XL kit. I used the OTO test, 5 drops of each. The Chlorine side looked like it stayed clear & the PH looked like it was the lowest color 6.8. Do I need to do any of the other tests before trying to get the PH right. I know I am going to need to SLAM the pool as I have been fighting Algea all year so far.
    AG18x48 6,800 gal TWM-30-S Sand filter, TWM-30 3/4 HP single speed pump Hayward SP1091WM Dyna-Skim Above-Ground Pool Skimmer Kit TF-100
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: JUST got TF-100 HELP please
    Congrats on the kit! Yes, start with getting pH right. Test for TA then use PoolMath to estimate the volume needed to raise pH to 7.4. Because your pH shows 6.8, it could actually be much lower since the test stops there. Your TA may be low as well.
    If TA is low, use washing soda or soda ash to raise both TA and pH. If TA is okay (>50), use borax to raise pH. Once you add, wait 30 minutes then retest pH. It may take a few additions to bring it up to 7.2-7.4 then start your slam! Good luck.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2016
    Lynchburg, VA
    66
    Thank You going to do TA test now. Hopefully, I understand it correctly
    Smykowski's Avatar
    Sep 2011
    3,065
    Do the FAS-DPD test for FC and CC. You will need precision and accuracy before and during the SLAM.
    38,284
    Just do all the tests and report back
    Pool Tool's Avatar
    May 2014
    757
    It is a weird one... for me anyway. Decent youtube videos out there if you need help. https://www.google.com/url?sa=t&rct=...Xx8jGp500F7S3A
    This is one test that is much easier with a speed stir, but it isn't required.
    May 2016
    Lynchburg, VA
    66
    OK so I came up with either 60 or 70, I really think 60 for TA
    May 2016
    Lynchburg, VA
    66
    So, if I am looking at this & the PoolMath right. Run to wally world & get a box of 20 Mule & add 58 OZ then wait 30 minutes & test again. Then if PH is good following SLAM directions?
    Pool Tool's Avatar
    May 2014
    757
    Assume 60. Add just over 3 lbs of borax then retest your TA. "Borax is available as 20 Mule TeamŽ Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return."
    As the others have said, while that circulates complete the rest of the test then retest pH (min. 30 minutes after borax).
    May 2016
    Lynchburg, VA
    66
    Gotcha will return with more #'s Thanks
    Aug 2015
    Grandy, NC
    135
    Pump on. Mix Borax in bucket of water to dissolve and pour into pool in front of return to get it circulating. And then wait 30 min and retest.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    May 2016
    Lynchburg, VA
    66
    Chlorine 0
    PH 6.8 OR lower
    TA 60
    Calcium Hardness 75
    CYA 35 ish
    Going to Wally World to get the 20 Mule Borax. Anything else to pick up while there?
    So don't add the Borax water mix thru the skimmer?
    38,284
    Nothing is ever added through the skimmer.
    May 2016
    Toms River, NJ
    61
    Is Wally World Walmart? If so, stock up on 10% pool chlorinating liquid, found by the pool chemicals. Should be $2.50/bottle. Or, stock up on 8.25% bottles of bleach (unscented and not the spashless kind). I'd say grab about 8 bottles. You don't want to run out when you start SLAMing.
    18k gal 32'x16' IG vinyl, sand filter, TF 100 test kit
    Newbie pool owner since April 2016
    May 2016
    Lynchburg, VA
    66
    Yes Wally World is Wal-Mart I think I have about 10 of those jugs of 10% Chlorine on hand
    Since I am above ground & Vinyl I don't really need to worry about my Calcium Hardness being 75 right?
    Pool Tool's Avatar
    May 2014
    757
    Correct, no need to worry about CH now.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Here is a sheet that describes pool chemicals and how to add them to your pool, Pool School - Recommended Pool Chemicals
    May 2016
    Lynchburg, VA
    66
    Will I need to bring my CYA up to 50 or am I good with it being about 35? Going to add Borax now then retest PH
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Don't raise CYA at all right now.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
  20. Back To Top    #20
    Mar 2015
    South Texas
    411
    Quote Originally Posted by Yankneck View Post
    Leave your CYA at 35 (round up to 40 for sanity reasons). It will make the SLAM a little easier. Then you can raise to 50 when SLAM is over
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
