Thread: New pool - clear, but....
    May 2015
    Martinsburg, WV
    4
    My new 7600 gallon agp is nice and clear, but not registering any chlorine. I've used the tabs. pH is 7.8, alkalinity 200. I just put the pH reducer in, and will retest soon. I'm assuming I need to shock the pool once I get the pH/alkalinity set, correct? Do I need a stabilizer? Anything else? CYA seems to be nonexistent.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: New pool - clear, but....
    Welcome to TFP and pool ownership.
    First question : How are you obtaining these results? What test kit/test method?
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    May 2015
    Martinsburg, WV
    4
    It's just the HTH test from Walmart.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Ok, first thing we'd suggest is to get your hands on a reliable and accurate test kit. We recommend the TF100 (Link in my signature) or the K-2006 (also available from tftestkits.net)
    Before you can really answer "What do I do next?" you need to have a good, reliable understanding of what's going on in your pool right now, and those kits will provide that information for you over the long term.
    While waiting for the kit, you should definitely read up on Pool School (link in my sig) so you can begin to understand why we test the way we do, and how we're going to react to those tests.
    In the meantime, adding half to a gallon of plain ole bleach (yep..just bleach from the laundry aisle) each day should do a fair job of keeping the things reasonably in line, and then if there's any issues we see in the test results, we can work from there.
    -Gordon
