Thread: Help identifying backwash valve
    Plano, TX
    11
    Can anyone help me identfy make and model of my backwash valve? Its leaking slightly so figure id get new orings but cant figure out which valve it is. Filter is a del60
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Help identifying backwash valve
    It's almost certainly the same brand as your filter. It would be too convenient if the manufacturers used the same spacing on their filter ports. Look for a label on the filter or post up a picture of it. Once the filter brand and model is known, the backwash valve ought to be easy to ID.
    And you've been a member for four years, maybe it's time you filled out your signature and location?
    Plano, TX
    11
    Thanks Richard. I put the model number of the filter in the original note: DEL60 CE filter. Guess I should have added Jandy to that. Your comment about manufacturer of the filter and valve makes sense, but my concern with just defaulting to a Jandy valve is because all the pics of Jandy valves I see on the internet look different than what I have with the non filter side ports being in different locations than the current valve, so figured I would add the pics to help identify.
    13K gal freeform with spa and waterfall, IG pebbletec, Jandy ProStealth 2HP single speed pump, Jandy ProMP 1.5HP waterfall pump, Pentair FNS Pro 60 DE filter (replaced 2016), Aqualogic PS8 with SWG, Polaris 280 with separate booster pump, Rheem 400kBTU heater (replaced 2015). Built August 2004. All original equipment except salt cell heater and filter.
    Richard320's Avatar
    Jan 2010
    19,002
