Thread: New member Pentair IC40 Problem
    Just converted my 32,000 gal inground (vinyl) pool to salt. Installed IC40 worked great for 2 days other than I put too much salt to start with. Had water tested and drained pool 1 foot at a time until salt was under 4200. Today my son changed pump from backwash to circulate and plugged cell back in. There is power on the power supply. No lights on cell at all. No power nothing. Checked voltage, fuse, I have no clue.... Anyone ever had any issues similar to this? Is there a thermal fuse in the cell that may reset? Maybe a bad cell?
    Thanks for any comments,
    Bo
    Re: New member Pentair IC40 Problem
    Welcome to TFP!
    The simple thing to try is to turn it off and back on again to see if it recovers. Then check the cables at both ends to be sure the power is plugged in and the cell is connected to the power supply.
    Thanks for the welcome. I wish I could have found this place while I was fighting my chlorine problems for the past couple of years.
    I have powered it off and on several times, still nothing. My wife just called my son and asked if he turned the power off before plugging the unit in...He said no. We also read about the self cleaning feature of the unit, but I wouldn't think it would do this after 2 days..I think we will call the company tomorrow. I have a feeling something is wrong with the cell.
    Thanks again for the reply.
    Bo
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    I'm a little confused as to why your son would "unplug" the unit to backwash the filter? Where did that recommendation come from?
    I'm with JasonLion. Do a power "reset".
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    billyjoeraybob's Avatar
    Apr 2008
    SC Midlands
    50
    I have the IC40 and the only time you need to "unplug" it is when you are physically removing the unit from the plumbing or to power cycle the unit.
    I hate to ask the obvious, but have you checked the plug is securely inserted into the power unit and the connector screwed in tight? Have any of your breakers tripped?
    Bill
    18' x 36' Freeform IG Gunite with 7' spa, Super Blue DiamondBrite, Pentair 1.5 hp circulation pump, Pentair 2.0 hp spa booster pump, Pentair Triton II Sand filter, Polaris 280 with booster pump, Pentair Intellichlor IC40 SWCG, Jandy Laars LX 250k btu NG heater, TF-100 test kit from http://www.tftestkits.com/
