Thread: Pebble vs Quartz Finish
    May 2014
    Dunellen nj
    20
    I will be having my pool re-plastered due to chipping in the spa and calcium nodules in the pool (thanks to TFP for helping to identify the problem). We are still under warranty and I plan on upgrading the finish to either quartz or pebble (PB doesn't install Pebble Tech), we now have white plaster. Any thoughts on which finish would be better for a re-plaster job, for bonding, and for durability, and maintenance, I have many very tall trees behind my property, so staining has been an issue. I also plan on having this done in September and then closing the pool for the season, so we can use the pool this year...it's only our third season. I wonder if the September date would be a good decision, or if it should be earlier. Any responses would be appreciated, thank you!
    Susan
    20,000 gal in ground free form white plaster pool
    Spa with spill over. SWG pool with DE filter and heat pump.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,758
    Re: Pebble vs Quartz Finish
    Either finish properly installed should last you many years. Pebble finishes are known for their longevity and often rough surface texture. Quartz may not last quite as long but will have a smoother finish. Your best bet would be to visit pools in your area to get a feel for what you'd like.
    I would be tempted to get the new plaster applied well before closing to make certain that the proper startup is done and water balance is maintained for several months during the critical curing period about 3-6 months from application.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2014
    Dunellen nj
    20
    Thank you for the information, I appreciate your expertise.
    Susan
