Results 1 to 14 of 14
Thread: How do you add bleach?
    Jun 2016
    Atlanta/GA
    33
    Measuring cup, bucket, etc. Trying to find the best way not to splash it. Is it as harmful as it says to the skin? I have never messed with bleach before, therefore I am not sure how scared of this stuff I should be. Pouring it over the rail near the water outlet to the pool is not the easiest with the jug.
    24' Round above ground, 52in deep, Cooper Ranger series 200# sand filter, 1.5 hp pump Jacuzzi pump
    May 2016
    Troy IL
    476
    Re: How do you add bleach?
    I bought a 1 quart pyrex measuring cup from walmart and use that to measure my manual doses. I like the large handle on it, and the pour spout makes it easy for me to pour the bleach into the pool without splashing. You still have to be careful while pouring the bleach into the measuring cup. Poor slow, and cautiously. The hardest part for me is opening the stupid paper/plastic seal they always have underneath the bottle cap without getting some bleach on your fingers. I haven't found a way to avoid that. I just wash my hands off in water quickly. I guess gloves would help, but I haven't done that yet.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I float the jug in the pool with the mouth of the bottle and inch or two above the water line and tip to pour. Don't have to hold a heavy jug and no splash. Although, I have gotten in a hurry and splashed some on me occasionally and it is no problem at all.
    I never pour it into a measuring cup. I just round to the nearest 1/4 of a jug or so.
    Jun 2016
    Atlanta/GA
    33
    I used a big crown Royal bottle tonight...right to the top of the crown is 56oz.. seemed to work good. I just filled it with a funnel.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    Best idea yet!!! I'm going to polish off my bottle of Crown just so I can try that.
    I float the jug in the water like pooldv.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Jun 2016
    Atlanta/GA
    33
    I had several laying around :0 It has a lid, and a nice handle. Funnel fits it nicely as well
    needsajet's Avatar
    Jan 2016
    4,237
    Gonna bring a Texas mickey of Crown back from Canada next visit! Anyway, back to pouring bleach or the mods will take away our whiskey
    My dad used to say: "Including decanting the 'shine, handle chemicals using the fewest steps that achieve an effective and repeatable result."
    Isaac-1's Avatar
    SW Louisiana
    6,711
    When I need to make a manual FC change I punch a small hole in the peel off tab with the tip of a knife and lay the jug sideways on the diving board, this will typically dispense 1/3 to 1/2 of a jug of bleach at a moderate drip before it stops flowing. 1 96 ounce jug of bleach adds about 2 ppm FC in my pool, so the 1/3 - 1/2 jug works out as about a 1 ppm boost to the pool, normal chlorination is handled by the metering pump.
    Jun 2016
    Atlanta/GA
    33
    How much are these pumps y'all speak of? I am going to ride this pool wall/ liner out as long as I can but I will need a new filter/pump in the fall. The liner is only 2 years old but the wall had a small amount of rust on. I treated it but I am sure it wont be the same. So i figure I can buy in chunks. Filter/pump this fall maybe new pool the following year or 2.
    needsajet's Avatar
    Jan 2016
    4,237
    Are you asking about chlorine dosing pumps? If so, try searching the forum for "stenner" and you'll find threads. You also might find rola chem and others.
    Other dosing options include the liquidator, Mas985's invention and saltwater chlorinators.
    Jul 2012
    Chicago, IL
    356
    I use a plastic juice pitcher. Marked off lines with a sharpie as to what level adds 1ppm, 2ppm, etc. I also kind of float it on the water surface so it pours consistently.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,321
    My pool typically needs 4 ppm FC added every 4 days which just so happens to be 1/2 a gallon of 8.25%
    I float the jug like PoolDV and slowly pour it 1 foot out from the deep end return jet.
    Dolphin E10 Cleaning Robot.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Letting the jug float partially while I pour makes it easy. I have a large pool so if I'm adding bleach, I'm always adding at least 1/2 gallon. No need to measure other than eyeballing half a jug. When I dose my SIGNIFICANTLY smaller spa, I have a 2 cup pyrex measuring cup that I steal from the kitchen. Accurate testing is more important than accurate measuring!
    Isolated Spa - 345 Gallons
    Jun 2016
    Atlanta/GA
    33
    Thanks!
