Thread: Pentair easy touch light control
    Jun 2016
    Naperville IL
    1
    I recently opened a new pool. We had the Easy touch Pentair device set up to control the lights in the pool. I am having trouble changing the light color and changing the modes. Everything else seems to be working as I can change pool temp and chlorinator. Has anyone else run into these issues?
    May 2015
    Land O Lakes, FL
    527
    Re: Pentair easy touch light control
    Yes this is the one thing I have not been able to figure out on the Easy Touch
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Apr 2015
    Brookline
    60
    Select the color and hit the back button, should start clicking right after
    Southern New Hampshire, 18x36 single roman end pool.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Do you have the color changing IntelliBrite and if so, how many lights do you have? You should be able to go into the Menu, then Lights then select Color.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
