Results 1 to 10 of 10
Thread: TA almost doubled?
    Mar 2016
    Chicago,IL
    88
    TA almost doubled?
    So my TA has gone up from 110 to 190 in about 2 weeks. I added 40lbs of Proteam supreme and
    was curious if this is what caused the increase? Should I be concerned at it being that high? Everything else is spot on and seems to be holding well
    Test results
    Ph-7.6
    fc-5
    cc-0
    ta-190
    borates-50
    cya-28
    19k 15x36' inground oval vinyl lined pool with deep end. 3 returns , 1 skimmer, 1 main drain. TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: TA almost doubled?
    Let us examine the clues.
    Aha! The MSDS says it contains Sodium tetraborate pentahydrate and some kind of proprietary ingredient, likely dry acid to neutralize the pH incrase. Exact percentages aren't given.
    So... going to pool math and inputting 19000 gallons at the top and then scrolling down to Effects of Adding Chemicals... 640 ounces of Sodium tetraborate pentahydrate will raise pH by 5.62, raise borate by 37 and raise TA by <drumroll> 86.
    So the stuff isn't 100% and the acid cancelled the pH rise but the TA is pretty much in the ballpark.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    It would appear you are trying to mix pool store advice and TFP advice. It won't work!
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Now you need to do this, Pool School - Lower Total Alkalinity
    Mar 2016
    Chicago,IL
    88
    Quote Originally Posted by tim5055 View Post
    I am?
    Quote Originally Posted by pooldv View Post
    Is having that high a level of TA bad as long as my PH is spot on?
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Countpyro1? What was your intentions with the ProTeam Supreme? Was there some imbalance going on you were looking to correct? Or did you just want to add a water enhancer?
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Mar 2016
    Chicago,IL
    88
    Quote Originally Posted by mikemass View Post
    I added it for the borates. They had it pretty cheap and wanted to give it a try. It's oh neutral so I didn't have to need with the Acid. Maybe it's Proteam supreme plus or what ever it's called. I know I could of done it cheaper with 20 mile or borax but had some gift store credit I had to use up so bought this instead.
    Actually it's TFP advise....
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I think what he meant by pool store advice is that proteam plus could be considered a "potion."
    Dolphin E10 Cleaning Robot.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If your TA is high it's not really a concern for a vinyl pool other than the potential for faster pH rise.
    Isolated Spa - 345 Gallons
    DFW, TX
    24,497
    No, generally having high TA is not bad. It will put upward pressure on your PH and it will rise faster. So, just keep a closer eye on PH and lower it as needed.
