Thread: Cloudy water with good numbers?
    georgiadawg's Avatar
    Jul 2014
    Eastanollee GA
    93
    Hi. I still have slightly cloudy water. Have been running pump and changing filter non stop but it's still cloudy. Tried taking FC up and keeping slightly above normal for several days (10), but still cloudy.
    Had very hot, very sunny weekend.
    Latest numbers:
    FC: 6
    CC: 0
    Ph:7.2
    TA: 70
    CYA: *40, BUT I don't think it's all registering yet. When we filled the pool I only had half the amount needed on hand. Had to add rest of it about a week later.
    Salt: 3400
    Can't understand why I can't get it clear. The numbers don't seem (to me) to indicate need for SLAM, but should I do it anyway?
    Lisa
    Northeast Georgia Pro Series above ground circular metal frame set pool 22' x 52". 11,400 gal capacity. w/ Skimmer plus 2000 pump/filter. Cartridge filter (Type C)
    Intex Krystal Clear Saltwater System Model CS8110
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Cloudy water with good numbers?
    Try doing an Overnight Chlorine Loss Test to see if there is anything doing on in the pool.
