Results 1 to 8 of 8
Thread: Cooling off the pool deck
    yzf600's Avatar
    Apr 2013
    Phoenix, AZ
    24
    Here in the desert, it doesn't matter what "cool" surface you place on the pool deck, it's going to get uncomfortably hot to walk on. A quick dousing of the deck with a couple of buckets of water cool it down nicely.
    Since I was going to re-do my deck with travertine, I was thinking I should install a couple of rotor sprinklers that would spray down the deck & pool for a couple of minutes to cool it off. The water source would come from the current pool fill line, that's actually after my water softener. Can anyone think of a reason not to do this, other than it makes the entire deck slippery all at once?
    15k gallon, salt water, plaster, Pentair IntelliFlo pump, Hayward 48 sq ft DE filter, Pentair Intellichlor, hayward Aquanat 200 pool vac ultra located in Phoenix, AZ
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Cooling off the pool deck
    It might leave some hard water/scale stains as the water evaporates and leaves behind the calcium. But, those will be white and if your travertine is light/white then it probably won't be very noticeable. I think that travertine will be a lot cooler anyway and maybe you won't need the deck cooler anyway.
    yzf600's Avatar
    Apr 2013
    Phoenix, AZ
    24
    There won't be much calcium left behind since it's softened water. I have some similarly light colored travertine on my patio that is just as hot as the current pool deck. When the air temp is 115, that IR heating from the ball of fire in the sky really adds up.
    DFW, TX
    24,483
    Oops, I misread that and my response was based on water before the water softener. I agree that it will be fine. Bummer about the hot feet! I would have thought the travertine would have been a bit cooler.
    Jan 2016
    TX
    157
    Start each session off with a quick jump and cannon ball.. works on mine
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    yzf600, how thick is the travertine on your patio or deck and what is the base?
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Isaac-1's Avatar
    SW Louisiana
    6,711
    When I read message threads like this it makes me so glad I have an indoor pool
    DFW, TX
    24,483
    Yeah, I'm a little jealous.
