Thread: Hiimmeruu
    Jun 2016
    DeFuniak Springs, FL
    1
    Hiimmeruu
    Hi new pool owner and am filling it now! Spent a few hours leveling and flattening a spot in the yard for it today. It is a 14' x 4' or so above ground pool.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Hiimmeruu
    Welcome to TFP!!
    Please be sure the installation location is not only flat, but level. Several people show up each year asking what they can do because "my pool is only 4 inches out of level". The industry standard is 1", which you really need tools to determine before you add water. You can't tell by just looking.
    Support the site
    Jun 2014
    15,298
    Re: Hiimmeruu
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Hiimmeruu
    Welcome!
    Have you seen Pool School - Guide for Seasonal/Temporary Pools ? Your pool is right on the cusp between a temporary pool that's easier to dump and refill in the event of a chemical catastrophe and a full-sized pool that requires a full-sized test kit to deal with problems in place. I'd err to the high side and get a proper test kit, but that's only because I've seen the results of having full control of the pool chemistry firsthand.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Hiimmeruu
    Welcome to the forum!
