Thread: Adding chlorine to new pool while filling.
    Jun 2016
    Marengo/IL
    48
    Brand new above ground pool is installed and filling with water. It's about half full and I tested the water. CL is .5 and pH is 7.5. If I add chlorine before the pool is full and filter is running do I stir up the water to be sure it's evenly distributed?
    TerriP
    27'x54" AGP - 2HP Hayward SWIMPRO LX PUMP - SW150 Hayward SWIMPRO Voyager Element Tank- - Dyna-Skim Wide Mouth Skimmer SP1091WM - Aquaray vaccuum
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Adding chlorine to new pool while filling.
    Quote Originally Posted by TerriP View Post
    Yes, that is best
    Support the site
    Jun 2016
    Marengo/IL
    48
    I should have written, "how do I stir up the water after adding bleach if the pool is not filled, yet?"
    TerriP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    A pool brush works.
    Realistically, raising half your pool volume up to 2.5 FC will only take three cups of bleach. You can slosh that in and direct the hose stream where you poured it and shake it around a little to get the bleach to disperse.
    Jun 2014
    15,298
    Just use your brush and sweep around a bit as best as you can.
