Results 1 to 13 of 13
Thread: Filling with garden hose, safe?
    Nov 2015
    Ok ok
    823
    I noticed the garden hose that I used to fill my pool gives off a terrible smell when dispensing hot water after it has been sitting in the sun. Also, I tasted just a bit of it and could tell the garden hose taste was present. This of course is only when the hot water from the sun is in the hose that has been sitting there. I had never really thought about this, but should I be concerned about filling my pool with this hose? I would like to think that after the water has run through the pool and displaced all of the hot water, that any dangerous chemicals would be removed or at least reduced to a safe level? I am concerned of course because my grandchildren swim in the pool. Does anybody have any insight on this? I'm probably just being paranoid, but would like to know everybody's thoughts on this. Now of course, while swimming I keep thinking I can have a strange taste, but I'm thinking is just from the salt addition.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    38,537
    Re: Filling with garden hose, safe?
    Some hoses do release chemicals that you would not want to drink (this is why there are special hoses used for drinking water). Problem is worse for the hot stagnant water (like how you should not drink bottle water that has sat in a hot car).
    I think if you turn the hose and and water the grass until the stagnant water out, then you would not really be adding much of anything to the pool.
    May 2013
    Massachusetts
    148
    What else would you fill your pool with exactly?
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Jun 2015
    Ottawa/Ontario
    340
    If you are that concerned, get a hose that os safe for drinking from.
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Nov 2015
    Ok ok
    823
    Quote Originally Posted by weird_tolkienish_f View Post
    They make hoses that are chemical and lead free that are safe for drinking from, the hose I used is not such. These chemical free hoses are common, the one I used came with the house, wish I would not used it but I am hoping that once the water ran through it that it was good water coming out. If I was doing it over, I would have made sure the hose was hazard free. You can buy them anywhere. Hoping someone here would have some insight.
    Nov 2015
    Ok ok
    823
    Quote Originally Posted by tlevy View Post
    I fully intend on doing that, my question is the water in my pool currently, is it safe?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    While the quart or so of water that was setting in the hose may have some chemical contaminants in it, by the time that is diluted into thousands of gallons of water, it's of no concern. That is of course assuming that your swimming pool is not your primary source of all drinking water.
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    On a side topic the ones that are drinking water safe are typically white with a stripe
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    RV supply hoses are made to be drinking water safe. They are usually white.
    chiefwej
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also I don't know what length you need, but Amazon had a really cheap price on a 25 ft drinking water safe hose a couple of weeks ago. (I ordered one for a non-pool project) Amazon.com: Camco 22783 TastePURE Drinking Water Hose (5/8) - Lead Free: Automotive Overall it seems good, but does have a plastic connector.
    Nov 2015
    Ok ok
    823
    Thanks everybody, I figured after the contaminated water was displaced the ensuing water would be fine. Just wanted verification for peace of mind. I always want to be sure I'm not doing anything that would put harm to my grandchildren.
    May 2013
    Massachusetts
    148
    Quote Originally Posted by Lykly View Post
    There's no such thing as chemical free. Even you are a mix of carbon and hydrogen.
    Quote Originally Posted by chiefwej View Post
    Drinking stagnant hose water that has been out in the sun? Yum!
    DE, Hayward Filter
    Loud pump
    Jun 2015
    Ottawa/Ontario
    340
    I think what he meant to say was hoses that do not leach as many chemicals as your standard garden hose. But point is well made - we are all a bunch of hydrogen, oxygen, nitrogen(?) and carbon, with some other trace elements to make up the rest...
