Thread: Newly Filled pool with town water
    18-20k gallon gunite pool with fiberglass walls.
    Brand new k2006 test kit numbers -
    FC - 1.6
    CC - .2
    pH - 7.6
    Alk - 80
    CH - 60
    CYA - 0
    The water is clear but is slight yellow-brownish (see pics). I know I have to raise my CH to between 250-300 and I'd like my CYA in the 40-50 range.
    I did scrub and vacuum the pool.
    What should my next step be? Any/all help is appreciated. Thanks!
    17 x 34 Concrete w/Fiberglass Walls IGP (Kidney) 18-20K Gallons
    Hayward Pro Series S210T Sand Filter
    1 HP Hayward Super Pump
    Taylor K-2006
    Located in MA
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: Newly Filled pool with town water
    Hmmm....what an interesting color! Are you sure you don't have metals in the water? Did you put anything in there like algaecide or other potion?
    You need to raise your CYA to appropriate levels and your FC first- Pool School - Recommended Levels
    I would recommend using bleach right off to give it that immediate punch of chlorine that it needs.
    Then you can work on the CH.
    And if the color remains, take a sample to the pool store and ask them to test for metals.
    Quote Originally Posted by YippeeSkippy View Post
    Yes, I did put in some algaecide as well as a Stain & Scale control to help prevent metallic stains.
    When initially filled with town water, it was a green color until I added the Stain & scale, as well as 4 bags of shock. The water seemed to clear after that
    but then after I had opened and closed the main + skimmer lines to get the appropriate skimmer suction correct, the water immediately turned green and then this dark brown but was still clear. I added some bleach which seemed to change the color to a lighter brown/yellowish tint where it lists now.
    Note - we did not open the pool at all last year so there may have been some remnants lingering in the main/skimmer line that found its way
    back into the pool when I opened/closed those lines.
    Taylor K-2006
    Located in MA
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Let's just hope it's tannic acid from some leaves that have been rotting into compost, and not metals. But if it was greenish before things got circulating, that seems unlikely. Sometimes the green goes away on its own. You can hasten the process by layering paper towels inside the skimmer basket. Or some polyester pillow/quilt batting if you have any scraps laying around with your craft supplies. A Tale of Two Filters... and Ugly, Rusty Water.
    CYA is easy.. plug numbers into poolmath and measure out the appropriate amounts into some socks. Since the skimmer will be full of paper towels, you'll want to suspend them in front of the returns.
    And as a point of interest... when you test FC and CC, use only 10 ml of water and one scoop of powder and count each drop as .5. It's accurate enough for us and saves a lot of reagents.
    If you need more information on what chemical does what and how to add it: Pool School - Recommended Pool Chemicals
    How to figure quantities is explained in Pool School - PoolMath Take a minute to read that. There are features in poolmath you might miss if you jump straight into it.
    Awesome! Thank you so much for your great advice!
    Taylor K-2006
    Located in MA
